Hi , am enounter this error . May i know how to resolve TXT issue
My domain is: athmanagement.com
[root@localhost ~]# /www/server/panel/pyenv/bin/python -u /www/server/panel/class/acme_v2.py --renew=1
|-A total of 2 certificates need to be renewed
|-Renewing certificate number of 1,domain: ['app.athmanagement.com']..
|-Creating order..
|-Getting verification information..
|-Verification type: dns-01
|-Verifying domain name..
|-Attempt to verify DNS records locally, domain name: acme-challenge.app.athmanagement.com, type: TXT record value: OJITZsVzXGJC8-zRXJRLO5zLL7IRN0oGQ2Ob7zIOQ-g
/www/server/panel/class/acme_v2.py:919: DeprecationWarning: please use dns.resolver.resolve() instead
ns = dns.resolver.query(domain, s_type)
|-Number of verifications: 1, value: 3e7y9sU4vWUylgbMW31vS-kGNC2mU5jjOlSC_xeOkhY
|-Number of verifications: 2, value: 3e7y9sU4vWUylgbMW31vS-kGNC2mU5jjOlSC_xeOkhY
|-Number of verifications: 3, value: 3e7y9sU4vWUylgbMW31vS-kGNC2mU5jjOlSC_xeOkhY
|-Number of verifications: 4, value: 3e7y9sU4vWUylgbMW31vS-kGNC2mU5jjOlSC_xeOkhY
|-Number of verifications: 5, value: 3e7y9sU4vWUylgbMW31vS-kGNC2mU5jjOlSC_xeOkhY
|-Number of verifications: 6, value: 3e7y9sU4vWUylgbMW31vS-kGNC2mU5jjOlSC_xeOkhY
|-Number of verifications: 7, value: 3e7y9sU4vWUylgbMW31vS-kGNC2mU5jjOlSC_xeOkhY
|-Number of verifications: 8, value: 3e7y9sU4vWUylgbMW31vS-kGNC2mU5jjOlSC_xeOkhY
|-Number of verifications: 9, value: 3e7y9sU4vWUylgbMW31vS-kGNC2mU5jjOlSC_xeOkhY
|-Number of verifications: 10, value: 3e7y9sU4vWUylgbMW31vS-kGNC2mU5jjOlSC_xeOkhY
|-Number of verifications: 11, value: 3e7y9sU4vWUylgbMW31vS-kGNC2mU5jjOlSC_xeOkhY
|-Number of verifications: 12, value: 3e7y9sU4vWUylgbMW31vS-kGNC2mU5jjOlSC_xeOkhY
|-Number of verifications: 13, value: 3e7y9sU4vWUylgbMW31vS-kGNC2mU5jjOlSC_xeOkhY
|-Number of verifications: 14, value: 3e7y9sU4vWUylgbMW31vS-kGNC2mU5jjOlSC_xeOkhY
|-Number of verifications: 15, value: 3e7y9sU4vWUylgbMW31vS-kGNC2mU5jjOlSC_xeOkhY
|-Number of verifications: 16, value: 3e7y9sU4vWUylgbMW31vS-kGNC2mU5jjOlSC_xeOkhY
|-Number of verifications: 17, value: 3e7y9sU4vWUylgbMW31vS-kGNC2mU5jjOlSC_xeOkhY
|-Number of verifications: 18, value: 3e7y9sU4vWUylgbMW31vS-kGNC2mU5jjOlSC_xeOkhY
|-Number of verifications: 19, value: 3e7y9sU4vWUylgbMW31vS-kGNC2mU5jjOlSC_xeOkhY
|-Number of verifications: 20, value: 3e7y9sU4vWUylgbMW31vS-kGNC2mU5jjOlSC_xeOkhY
|-Local authentication failed!
|-1 Query verification results..
|-Verification failed
|-A wrong TXT record was found on ['_acme-challenge.app.athmanagement.com']: ['3e7y9sU4vWUylgbMW31vS-kGNC2mU5jjOlSC_xeOkhY'], please check whether the TXT resolution is correct, if it is applied by DNSAPI, please try again in 10 minutes!
|-Renewing certificate number of 2,domain: ['dev.athmanagement.com']..
|-Creating order..
|-Attempt to verify DNS records locally, domain name: acme-challenge.dev.athmanagement.com, type: TXT record value: aeESOtjtcM_Wc3aNAtba8GKHCoM1Zb78vicye3HzF2E
|-Number of verifications: 1, value: HTrdZBxamjh_VHRsTspaEOvWBwXuVcV8O8nlTebs54s
|-Number of verifications: 2, value: HTrdZBxamjh_VHRsTspaEOvWBwXuVcV8O8nlTebs54s
|-Number of verifications: 3, value: HTrdZBxamjh_VHRsTspaEOvWBwXuVcV8O8nlTebs54s
|-Number of verifications: 4, value: HTrdZBxamjh_VHRsTspaEOvWBwXuVcV8O8nlTebs54s
|-Number of verifications: 5, value: HTrdZBxamjh_VHRsTspaEOvWBwXuVcV8O8nlTebs54s
|-Number of verifications: 6, value: HTrdZBxamjh_VHRsTspaEOvWBwXuVcV8O8nlTebs54s
|-Number of verifications: 7, value: HTrdZBxamjh_VHRsTspaEOvWBwXuVcV8O8nlTebs54s
|-Number of verifications: 8, value: HTrdZBxamjh_VHRsTspaEOvWBwXuVcV8O8nlTebs54s
|-Number of verifications: 9, value: HTrdZBxamjh_VHRsTspaEOvWBwXuVcV8O8nlTebs54s
|-Number of verifications: 10, value: HTrdZBxamjh_VHRsTspaEOvWBwXuVcV8O8nlTebs54s
|-Number of verifications: 11, value: HTrdZBxamjh_VHRsTspaEOvWBwXuVcV8O8nlTebs54s
|-Number of verifications: 12, value: HTrdZBxamjh_VHRsTspaEOvWBwXuVcV8O8nlTebs54s
|-Number of verifications: 13, value: HTrdZBxamjh_VHRsTspaEOvWBwXuVcV8O8nlTebs54s
|-Number of verifications: 14, value: HTrdZBxamjh_VHRsTspaEOvWBwXuVcV8O8nlTebs54s
|-Number of verifications: 15, value: HTrdZBxamjh_VHRsTspaEOvWBwXuVcV8O8nlTebs54s
|-Number of verifications: 16, value: HTrdZBxamjh_VHRsTspaEOvWBwXuVcV8O8nlTebs54s
|-Number of verifications: 17, value: HTrdZBxamjh_VHRsTspaEOvWBwXuVcV8O8nlTebs54s
|-Number of verifications: 18, value: HTrdZBxamjh_VHRsTspaEOvWBwXuVcV8O8nlTebs54s
|-Number of verifications: 19, value: HTrdZBxamjh_VHRsTspaEOvWBwXuVcV8O8nlTebs54s
|-Number of verifications: 20, value: HTrdZBxamjh_VHRsTspaEOvWBwXuVcV8O8nlTebs54s
|-A wrong TXT record was found on ['_acme-challenge.dev.athmanagement.com']: ['HTrdZBxamjh_VHRsTspaEOvWBwXuVcV8O8nlTebs54s'], please check whether the TXT resolution is correct, if it is applied by DNSAPI, please try again in 10 minutes!
Troubelshooting:
i found the TXT entries record mention domain name does not exist but my domain still active .
