Hi guys, I am using lcget to manually authenticate with acme,
the problem is error: letsencrypt.plugins.manual:Self-verify of challenge failed.
it goes all well as you can see in the bottom log, however ive traced why the error occur but i dont know how to fix it.
basically acme is trying to find: miklaszewski.com/.well-known/acme-challenge/02CUfhjnMXxV2Z-QHie_2WJQdF5x16788VDPJe3cxk4 and its gets 403 and 404 error
however if you add “/” at the end like this:
http://www.miklaszewski.com/.well-known/acme-challenge/02CUfhjnMXxV2Z-QHie_2WJQdF5x16788VDPJe3cxk4/
it works fine
i do have .htaccess set to use .well-known/acme-challenge in http mode
but i cant make it work with “/” at the end so acme challange can pass
RewriteEngine On RewriteCond %{HTTPS} off RewriteCond %{REQUEST_URI} !^/.well-known/acme-challenge/ [NC] RewriteRule ^ https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
any idea how to fix this problem?
log:
https://bartron.org.uk/index.php/s/VTdzSWPxjIa3ByL
I'm a little confused. ACME should correctly be trying to check the file at miklaszewski.com/.well-known/acme-challenge/02CUfhjnMXxV2Z-QHie_2WJQdF5x16788VDPJe3cxk4 ( without a trailing slash )
so I'm not sure why you want to add a trailing slash on the end. It shouldn't be there as far as I'm aware.
If I try to go to the correct link of miklaszewski.com/.well-known/acme-challenge/02CUfhjnMXxV2Z-QHie_2WJQdF5x16788VDPJe3cxk4 I get a redirect
$ curl -I http://www.miklaszewski.com/.well-known/acme-challenge/02CUfhjnMXxV2Z-QHie_2WJQdF5x16788VDPJe3cxk4
Location: http://www.miklaszewski.com/.well-known/acme-challenge/02CUfhjnMXxV2Z-QHie_2WJQdF5x16788VDPJe3cxk4/
Server: - Web acceleration by cPanel Varnish Plugin for better website performance
X-Cacheable: YES
Content-Length: 307
Accept-Ranges: bytes
Date: Fri, 27 May 2016 18:30:39 GMT
X-Varnish: 1690420832 1690420498
Via: 1.1 varnish
X-Cache: HIT
X-Cache-Hits: 1
Is it the self verify that's failing ? or the ACME check ?
system
Closed
3
