Being a noob to the lets encrypt system, I thought I'd give it a go on a kemp load master by following this documentation: Progress Documentation
I successfully requested and pulled the cert, just to test, I was able to renew it once there and then shortly after the pull. However, when I want to renew the cert manually again it fails each time with "unable to communicate with CA"
That's most likely some kind of comms problem. Do you have any other diagnostic tools you can run from that device? Is there anything between that Kemp device and the internet (like firewalls, routing gear, and such)?
No limitations or restrictions, using Google dns, when I manually try to renew it’s very hit and miss, most times CA is unavailable message appears, sometimes it renews ok.
All we (the community) could really suggest is either a flaky OS, buggy client or a network issue and your best bet is to contact your vendor (Progress). Code 28 is probably a curl connection timeout.
If using something like curl to query https://acme-v02.api.letsencrypt.org/directory consistently works then generally connectivity is OK, but there could still be a firewall or similar being selective about allowed processed or allow target IPs etc.
I'd get the certificate on a different system then deploy it to your target device.
