Issues Setting up a Secondary Server
I’m trying to set up a secondary server that I can switch to when the need arises. There is an issue. When I switch to the secondary, the HTTPS redirect gets in the way. I can’t just copy from the primary to the secondary and I can’t just get new certificates on the secondary server without errors. Any Suggestions?
OS Ubuntu 16.04
Web Server: Apache 2.4
What’s preventing you from copying to the secondary server? The only ‘good’ alternative is using DNS challenges instead on the secondary, but that’s only feasible in certain configurations.
