The full domain name of your site: test.net (obviously testing in this case, working on a Proof of Concept)
The command line you ran: certbot-auto certonly -d test.net --noninteractive --apache --agree-tos --email ****
The output of that command: See bottom output
Name and version of your operating system and your web server: CentOS release 6.5 (Final), Apache 2.4.2/Tomcat 7.0.77
What type of hosting provider you are using, if applicable: AWS
Output from the commands seem to point towards an issue detecting and confirming apache. This is a proprietary set up so I’m guessing certbot can’t detect the processes in this scenario. It also doesn’t detect HTTPD despite the processes running. Additionally, we use a custom configuration for vhosts that applies to multiple configuration files. This is all a POC example so I’m not even sure if this is possible (and I don’t want to share too much company information as well).
Output:
http-01 challenge for test.net
httpd not running, trying to start
(98)Address already in use: make_sock: unable to listen for connections on address [::]:80
(98)Address already in use: make_sock: unable to listen for connections on address 0.0.0.0:80
no listening sockets available, shutting down
Unable to open logs
Unable to restart apache using [‘apachectl’, ‘graceful’]
Error while running apachectl restart.
Unable to open logs
Encountered exception during recovery
Unable to open logs
File “/opt/eff.org/certbot/venv/lib64/python3.4/site-packages/certbot/auth_handler.py”, line 73, in handle_authorizations
resp = self._solve_challenges(aauthzrs)
File “/opt/eff.org/certbot/venv/lib64/python3.4/site-packages/certbot/auth_handler.py”, line 124, in _solve_challenges
resp = self.auth.perform(all_achalls)
File “/opt/eff.org/certbot/venv/lib64/python3.4/site-packages/certbot_apache/configurator.py”, line 2117, in perform
http_response = http_doer.perform()
File “/opt/eff.org/certbot/venv/lib64/python3.4/site-packages/certbot_apache/http_01.py”, line 70, in perform
self._mod_config()
File “/opt/eff.org/certbot/venv/lib64/python3.4/site-packages/certbot_apache/http_01.py”, line 97, in _mod_config
for vh in self._relevant_vhosts():
File “/opt/eff.org/certbot/venv/lib64/python3.4/site-packages/certbot_apache/http_01.py”, line 134, in _relevant_vhosts
" {0}.".format(http01_port))
certbot.errors.PluginError: Unable to find a virtual host listening on port 80 which is currently needed for Certbot to prove to the CA that you control your domain. Please add a virtual host for port 80.
File “/opt/eff.org/certbot/venv/lib64/python3.4/site-packages/certbot_apache/configurator.py”, line 2021, in _reload
util.run_script(self.constant(“restart_cmd”))
File “/opt/eff.org/certbot/venv/lib64/python3.4/site-packages/certbot/util.py”, line 85, in run_script
raise errors.SubprocessError(msg)
certbot.errors.SubprocessError: Error while running apachectl graceful.
Unable to open logs
File “/opt/eff.org/certbot/venv/lib64/python3.4/site-packages/certbot/error_handler.py”, line 103, in _call_registered
self.funcs-1
File “/opt/eff.org/certbot/venv/lib64/python3.4/site-packages/certbot/auth_handler.py”, line 308, in _cleanup_challenges
self.auth.cleanup(achalls)
File “/opt/eff.org/certbot/venv/lib64/python3.4/site-packages/certbot_apache/configurator.py”, line 2148, in cleanup
self.restart()
File “/opt/eff.org/certbot/venv/lib64/python3.4/site-packages/certbot_apache/configurator.py”, line 2011, in restart
self._reload()
File “/opt/eff.org/certbot/venv/lib64/python3.4/site-packages/certbot_apache/configurator.py”, line 2039, in _reload
raise errors.MisconfigurationError(error)
certbot.errors.MisconfigurationError: Error while running apachectl restart.
Unable to open logs
