http-01 challenge for sendy.ventefidelite.com
Challenge failed for domain sendy.ventefidelite.com
My web server is (include version): Apache HTTP Server 2.4.41
The operating system my web server runs on is (include version): Ubuntu 20.04.4 LTS
My hosting provider, if applicable, is: Digital ocean
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.40.0
Hi @mmazraani and welcome to the community!
Your error response says LE Servers are trying to connect to your server on port 80 (http)
When checking your IP it looks like port 80 is being "filtered" and therefore is is not allowing LetsEncrypt to validate your system.
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
VirtualHost configuration:
*:443 is a NameVirtualHost
default server sendy.ventefidelite.com (/etc/apache2/sites-enabled/000-default-le-ssl.conf:2)
port 443 namevhost sendy.ventefidelite.com (/etc/apache2/sites-enabled/000-default-le-ssl.conf:2)
port 443 namevhost 159.203.4.211 (/etc/apache2/sites-enabled/159.203.4.211.conf:1)
*:80 is a NameVirtualHost
default server 127.0.1.1 (/etc/apache2/sites-enabled/000-default.conf:1)
port 80 namevhost 127.0.1.1 (/etc/apache2/sites-enabled/000-default.conf:1)
port 80 namevhost 159.203.4.211 (/etc/apache2/sites-enabled/159.203.4.211.conf:9)
Digital Ocean is primarily a self-serve VPS provider. In case they cannot provide sufficient detail, here are some DO guides that pertain to both the firewall running in your Droplet's operating system and the DO Cloud Firewall.
