Issue with nginx & active24
Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. crt.sh | ucimesejs.cz), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is: ucimesejs.cz
I ran this command: sudo certbot --nginx -d ucimesejs.cz -d www.ucimesejs.cz
It produced this output: Domain: ucimesejs.cz
Detail: 2a00:4b40:aaaa:2005::7: Invalid response from http://ucimesejs.cz/.well-known/acme-challenge/NUpgurZFeimV5c0vjG5ssG25InT7-CevqhjJ3CP1_no: 404
Domain: www.ucimesejs.cz
Detail: 2a00:4b40:aaaa:2005::7: Invalid response from http://www.ucimesejs.cz/.well-known/acme-challenge/mgRupf67klatwzuInohEOhXmmokDRZxjfd9a96sKhis: 404
My hosting provider, if applicable, is: dedicated server
❯ certbot --version
certbot 1.21.0
letsencrypt.txt (162.8 KB)
Hi @cooffeeRequired, and welcome to the LE community forum :slight_smile:
"detail": "2a00:4b40:aaaa:2005::7: Invalid response from http://ucimesejs.cz/.well-known/acme-challenge/REiOM00a5VNqR0J4n5LdovexC-1TpYCFTRwVmDGgoR4: 404",
Does your site work via IPv6?
curl -Ii4 ucimesejs.cz     <<<<<<<<<<<<<<<<<<<<<<<<< IPv4
HTTP/1.1 200 OK
Server: nginx/1.18.0 (Ubuntu)     <<<<<<<<<<<<<<<<<<<<<<<<< NGINX
Date: Tue, 05 Dec 2023 23:50:36 GMT
Content-Type: text/html
Content-Length: 612
Last-Modified: Tue, 05 Dec 2023 23:27:49 GMT
ETag: "656fb1f5-264"
Accept-Ranges: bytes
curl -Ii6 ucimesejs.cz     <<<<<<<<<<<<<<<<<<<<<<<<< IPv6
HTTP/1.1 200 OK
Server: openresty     <<<<<<<<<<<<<<<<<<<<<<<<< OPENRESTY
Date: Tue, 05 Dec 2023 23:50:41 GMT
Keep-Alive: timeout=10
Vary: Accept-Encoding
the ipv6 was configured from Active24... I noticed it only now, I removed the AAAA records and now I'm waiting until I can do another validation. because I exceeded the limit.,
The one hour limit?
Yes that one
❯ less /var/log/nginx/error.log
❯ sudo certbot --nginx -d ucimesejs.cz -d www.ucimesejs.cz
[sudo] password for coffee:
Requesting a certificate for ucimesejs.cz and www.ucimesejs.cz
An unexpected error occurred:
There were too many requests of a given type :: Error creating new order :: too many failed authorizations recently: see https://letsencrypt.org/docs/failed-validation-limit/
╭─    /var/www/html 
Let us know how this goes.
[ once you've woken up and had the required amount of cooffee :wink: ]
