The Certificate I have is about to expire, so I am in process of renewing it using certbot.
Getting the bellow error while running the queries “./certbot-auto renew” “./certbot-auto renew --dry-run”.
/opt/eff.org/certbot/venv/lib/python2.6/site-packages/cryptography/init.py:26: DeprecationWarning: Python 2.6 is no longer supported by the Python core team, please upgrade your Python. A future version of cryptography will drop support for Python 2.6
DeprecationWarning
Processing /etc/letsencrypt/renewal/supplychain.sit.hmdglobal.com.conf
Could not choose appropriate plugin: The manual plugin is not working; there may be problems with your existing configuration.
The error was: PluginError(‘An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.’,)
Attempting to renew cert (supplychain.sit.hmdglobal.com) from /etc/letsencrypt/renewal/supplychain.sit.hmdglobal.com.conf produced an unexpected error: The manual plugin is not working; there may be problems with your existing configuration.
The error was: PluginError(‘An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.’,). Skipping.
/etc/letsencrypt/live/supplychain.sit.hmdglobal.com/fullchain.pem (failure)
What can be done to rectify this issue or is there any better way to renew a certificate?
Thanks
