I ran this command: sudo certbot --apache -d aqaj.org
Output:
"Obtaining a new certificate
http-01 challenge for aqaj.org
Waiting for verification…
Failed authorization procedure. aqaj.org (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://aqaj.org/.well-known/acme-challenge/Q6MkISlID_N1xaOd6SdPLx4AUD6wEFzMSJZZ0i_Ou5s: “\r\n\r\n\r\n\t\r\n\tAccueil Association Qu\xe9b\xe9coise des Administrat”
Your account credentials have been saved in your Certbot
making regular backups of this folder is ideal."
When I ping aqaj.org, it resolves to the correct DNS (my droplet).
My web server is (include version): apache
The operating system my web server runs on is (include version): linux ubuntu 14.04
It seems certbot is having trouble placing the challenge file in the correct folder.
Please place a test.txt file as: http://aqaj.org/.well-known/acme-challenge/test.txt
Options All -Indexes
# Deny access to .htaccess
<Files .htaccess>
order allow,deny
deny from all
satisfy all
</Files>
# Deny access to php.ini
<Files php.ini>
order allow,deny
deny from all
satisfy all
</Files>
# Deny access to php_error.log
<Files php_error.log>
order allow,deny
deny from all
satisfy all
</Files>
RewriteEngine on
RewriteBase /
# Prevent any kind of looping:
RewriteCond %{ENV:REDIRECT_STATUS} 200
RewriteRule ^ - [L]
# Rewrite links to index.php
# RewriteCond %{REQUEST_URI} !^/index\.php
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule ^(.*)$ index.php?uri=$1 [L]
How should I edit this file to accomodate let’s encrypt and redirect all traffic to https?
The htaccess redirection is used for internal website structure purposes. It transforms all URLs into GET requests. It does not, as of now, redirect to https.
Since you said:
I am wondering how to edit my current htaccess file to solve the issue and allow let's encrypt to work properly.
I understand that when let's encrypt will be functioning properly, I'll have to edit again my htaccess to redirect http traffic to https.
Failed authorization procedure. aqaj.org (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://aqaj.org/.well-known/acme-challenge/mNVPie10PNzV8ojgxDs8510fgUiaa_Qb1s9Oy6Cxxi0: "<!DOCTYPE HTML PUBLIC \"-//IETF//DTD HTML 2.0//EN\">\n<html><head>\n<title>404 Not Found</title>\n</head><body>\n<h1>Not Found</h1>\n<p"
Domain: aqaj.org
Detail: Invalid response from
What is causing the issue?
Could it have to do with the fact that my website root is not located in /var/www/html?
If you can load your file, you have found your correct webroot. So use this information to split authenticator and installation.
certbot run -a webroot -i apache -w pathToYourWebroot -d aqaj.org
That may be part of the problem. But if you have your correct webroot, you can use it.
PS: The file is without extension, so try 1234 as file name, not 1234.txt. Sometimes redirect rules have a different behaviour if the file has an extension or not.
