with new update on centos web panel of Letsenycrpt , i have installed but when i click to
add on account,i got below error.Please tell the solutions
WARNING! Letsenycrpt Certificate installation failed, please check /etc/letsencrypt/live/serverzon.com !
Bootstrapping dependencies for RedHat-based OSes…
yum is /usr/bin/yum
Setting up Install Process
Package redhat-rpm-config-9.0.3-51.el6.centos.noarch already installed and latest version
Package python-2.6.6-64.el6.x86_64 already installed and latest version
No package python-virtualenv available.
No package python-pip available.
Resolving Dependencies
–> Running transaction check
—> Package augeas-libs.x86_64 0:1.0.0-10.el6 will be installed
—> Package ca-certificates.noarch 0:2015.2.4-65.0.1.el6_6 will be updated
—> Package ca-certificates.noarch 0:2015.2.6-65.0.1.el6_7 will be an update
—> Package dialog.x86_64 0:1.1-9.20080819.1.el6 will be installed
—> Package gcc.x86_64 0:4.4.7-16.el6 will be updated
–> Processing Dependency: gcc = 4.4.7-16.el6 for package: gcc-c+±4.4.7-16.el6.x86_64
—> Package gcc.x86_64 0:4.4.7-17.el6 will be an update
–> Processing Dependency: libgomp = 4.4.7-17.el6 for package: gcc-4.4.7-17.el6.x86_64
–> Processing Dependency: cpp = 4.4.7-17.el6 for package: gcc-4.4.7-17.el6.x86_64
–> Processing Dependency: libgcc >= 4.4.7-17.el6 for package: gcc-4.4.7-17.el6.x86_64
—> Package libffi-devel.x86_64 0:3.0.5-3.2.el6 will be installed
—> Package openssl.x86_64 0:1.0.1e-42.el6 will be updated
—> Package openssl.x86_64 0:1.0.1e-48.el6_8.1 will be an update
—> Package openssl-devel.x86_64 0:1.0.1e-42.el6 will be updated
—> Package openssl-devel.x86_64 0:1.0.1e-48.el6_8.1 will be an update
—> Package python-devel.x86_64 0:2.6.6-64.el6 will be installed
—> Package python-tools.x86_64 0:2.6.6-64.el6 will be installed
–> Processing Dependency: tkinter = 2.6.6-64.el6 for package: python-tools-2.6.6-64.el6.x86_64
—> Package cpp.x86_64 0:4.4.7-16.el6 will be updated
—> Package cpp.x86_64 0:4.4.7-17.el6 will be an update
—> Package gcc-c++.x86_64 0:4.4.7-16.el6 will be updated
—> Package gcc-c++.x86_64 0:4.4.7-17.el6 will be an update
–> Processing Dependency: libstdc+±devel = 4.4.7-17.el6 for package: gcc-c+±4.4.7-17.el6.x86_64
–> Processing Dependency: libstdc++ = 4.4.7-17.el6 for package: gcc-c+±4.4.7-17.el6.x86_64
—> Package libgcc.x86_64 0:4.4.7-16.el6 will be updated
—> Package libgcc.x86_64 0:4.4.7-17.el6 will be an update
—> Package libgomp.x86_64 0:4.4.7-16.el6 will be updated
—> Package libgomp.x86_64 0:4.4.7-17.el6 will be an update
—> Package tkinter.x86_64 0:2.6.6-64.el6 will be installed
–> Processing Dependency: libtk8.5.so()(64bit) for package: tkinter-2.6.6-64.el6.x86_64
–> Processing Dependency: libtcl8.5.so()(64bit) for package: tkinter-2.6.6-64.el6.x86_64
–> Processing Dependency: libTix.so()(64bit) for package: tkinter-2.6.6-64.el6.x86_64
—> Package libstdc++.x86_64 0:4.4.7-16.el6 will be updated
—> Package libstdc++.x86_64 0:4.4.7-17.el6 will be an update
—> Package libstdc+±devel.x86_64 0:4.4.7-16.el6 will be updated
—> Package libstdc+±devel.x86_64 0:4.4.7-17.el6 will be an update
—> Package tcl.x86_64 1:8.5.7-6.el6 will be installed
—> Package tix.x86_64 1:8.4.3-5.el6 will be installed
—> Package tk.x86_64 1:8.5.7-5.el6 will be installed
–> Finished Dependency Resolution
Error: Multilib version problems found. This often means that the root
cause is something else and multilib version checking is just
pointing out that there is a problem. Eg.:
1. You have an upgrade for openssl which is missing some
dependency that another package requires. Yum is trying to
solve this by installing an older version of openssl of the
different architecture. If you exclude the bad architecture
yum will tell you what the root cause is (which package
requires what). You can try redoing the upgrade with
--exclude openssl.otherarch ... this should give you an error
message showing the root cause of the problem.
2. You have multiple architectures of openssl installed, but
yum can only see an upgrade for one of those arcitectures.
If you don't want/need both architectures anymore then you
can remove the one with the missing update and everything
will work.
3. You have duplicate versions of openssl installed already.
You can use "yum check" to get yum show these errors.
...you can also use --setopt=protected_multilib=false to remove
this checking, however this is almost never the correct thing to
do as something else is very likely to go wrong (often causing
much more problems).
Protected multilib versions: openssl-1.0.1e-48.el6_8.1.x86_64 != openssl-1.0.1e-42.el6.i686
Could not install OS dependencies. Aborting bootstrap!
