Issue in Creating Certificate using Lets Encrypt for the domain "test.asyncwq.cognizant.com"
I am getting below error when trying to create certificate using Lets Encrypt for the domain
Domain: test.asyncwq.cognizant.com
Failed authorization procedure. test.asyncwq.cognizant.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://test.asyncwq.cognizant.com/.well-known/acme-challenge/7YGSStSHZh3EBQc2VHxq6xD4EORJQ2aplZZvY6_YZhY: Timeout
    Type: connection
    Detail: Fetching
    Timeout
Can you please help me in resolving the below issue
wget test.asyncwq.cognizant.com
–2018-02-01 08:18:38-- http://test.asyncwq.cognizant.com/
Resolving test.asyncwq.cognizant.com (test.asyncwq.cognizant.com)… 185.39.229.61
Connecting to test.asyncwq.cognizant.com (test.asyncwq.cognizant.com)|185.39.229.61|:80… failed: Connection refused.
ok Let me check … thanks
