Currently, I am unable to generate the cert and key on my web host server (A Small Orange). This is on shared hosting. Whenever running the manual script, I receive the following message:
Command “python setup.py egg_info” failed with error code 1
I already know that the web host cannot update pip since this is on shared hosting. Is there any other way I can generate the cert and key for use on their server?
How do you recommend running this from the desktop? I just need the certificate and key generated, which I would then send onto my web host. I have downloaded the getssl script files; however, I did not see how to run the script from a desktop. Appreciate any help! Thanks!
if linux, then I’d run the getssl bash script ( as that will obtain the certificate and automatically upload it for you if you have SSH access )
If you can modify your DNS through an API then again the bash scripts will perform the DNS challenge for you ( that way you don’t need to upload any verification values to the server, you will just get the certs )
If windows, then it gets a little more tricky, and it depends how good you are with the CLI on windows, or if better to use an online config ( personally I’d prefer to use a linux virtualbox on your windows machine than an online system, that’s just a personal choice though - as it’s more secure, and can let you automate everything).
Ok, thanks for your response. Currently, I only have access to Windows and have used Putty to SSH into my site. Using that technology, I was able to create the getssl config files. However, nothing seems to happen when running the next script, getssl mydomain.com
Should I download and install ubuntu? And if so, I assume the latest version. Or is there another linux virtualbox you would recommend? I am on a Windows 10 desktop. Thanks a lot!
If you can SSH onto your site, why not use one of the bash scripts directly on your server / site ? That should enable you to create the certificate on the server, is probably the easiest solution.
Great, thanks! I did upload your script, getssl into a folder I created in the root directory /home/evoluti3. I did change permission on the getssl script and ran through SSH. It did create /.getssl folder with the config files. Do I need to change anything else to generate the cert and key? When running getssl mydomain.com, nothing appears to be created. Thanks!
If you run "getssl -c yourdomain.com " it will create /.getssl/yourdomain.com and in that there will be a config file. Edit that to point to the correct root directory ( i.e. where your your index.html for your website would be and /.well-known/acme-challenge on the end )
you can then run “getssl yourdomain.com” and it should create the certificates for you in /.getssl/yourdomain.com/ folder
OK - there is basic help etc on https://github.com/srvrco/getssl if I’m not around ( I’m UK based, so getting late here ) … will check in the morning though.
Just an update. I ran the scripts; however, I am not sure if it created all the files. I checked in the .getssl/mydomain.com folder and can only see one cert (mydomain.com.crt) file. I thought there are a few files as well as keys. Could those files be anywhere else? Thanks!
