Isrg-root-x1-cross-signed.pem has expired
My domain is: misterprotocol.photos
I ran this command: certbot certonly
It produced this output: The usual
My web server is (include version): None
The operating system my web server runs on is (include version): Macos Sequoia 15.2
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): None
I'm not running a web server. I'm using Let's Encrypt certs to encrypt an FTPS server in FileZilla Server. Why? Because I'm using Sony and Canon cameras to send pictures back to my FTP server, I want to use encryption, and the cameras have support for FTPS and that's all.
To do this, you have to install root certificates on the cameras. Some sort of problem with FileZilla Server prevents me from just generating and using my own root cert and certificate, so I decided to use Let's Encrypt, since FileZilla Server has support for generating and using a Let's Encrypt certificate. However, at least on my Canon camera, when I downloaded what I assumed to be the correct root cert for my freshly-generated certificate, and tried to load it into the camera, the camera said "This root certificate may be expired", and refused to load it. Sure enough, printing out the root cert shows a "Not After" date of last September. How do I fix this?
The cross-signed version of ISRG Root X1 (signed by DST Root CA X3) indeed expired in September. It has been retired for quite a while now. The root certificate you're looking for is the self-signed version of ISRG Root X1: https://letsencrypt.org/certs/isrgrootx1.pem
