I ran this command: sudo certbot certonly --webroot
It produced this output: Cannot use domain name as lineage name because it contains an illegal character (i.e. filepath separator). Specify an explicit lineage name with --cert-name.
My web server is (include version): Apache with ISPConfig (customer domain)
My hosting provider, if applicable, is: ISPconfig on VP
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): ISPConfig
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): Latest, updated
It seems that regardless of webfoot used, I cannot get past the request for webfoot. There are multiple domains / sites being run on this ISPConfig install,t
My apologies, I mistyped. Its asks for the webfoot, and since there are multiple domains set up on the server running Debian and ISPConfig. If the webfoot is for the particular domain, I’ll need to know the specifics of that, if its for the overall server, then that’s another story.
