My domain is: des9.de
I ran this command: ispconfig to generate a certificate
It produced this output: look at log file http://des9.de/.well-known/acme-challenge/des9.de
My web server is (include version): nginx 1.6.3
The operating system my web server runs on is (include version): CENTOS 7
My hosting provider, if applicable, is: nope
I can login to a root shell on my machine (yes or no, or I don’t know):yes - sure thing
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): ispconfig 3.1
Overall:
I can create and read files from acme-challenge directory locally and remotely (http port 80)
Somehow webroot authentication doesnt work - whatever I do…
Pleae help…
schoen
May 31, 2017, 12:09am
#2
kbi-user:
Your hostname is resolving to the IPv6 address 2001:8d8:934:5100::56:157b, but your webserver isn’t reachable at that IPv6 address.
Its resolving now the ipv6 address - I still get the same error. Apart from that, I dont get anymore logging by letsencrypt…
The error messages I receive by E-Mail:
31.05.2017-14:40 - WARNING - Could not verify domain des9.de , so excluding it from letsencrypt request.
Ill have to start another thread later on. As it turns out, my ipv6/nginx configuration is borked - this will take some to correct… Thank you for your info so far.
system
Closed
June 30, 2017, 2:14pm
#6
