My plan is to use systemd’s timers to monthly check expiring certs and renew them. Here are my files:
/etc/systemd/system/letsencrypt.timer
[Unit]
Description=Check monthly for which certs are expiring and renew them
[Timer]
OnCalendar=monthly
Unit=letsencrypt.service
[Install]
WantedBy=timers.target
/etc/systemd/system/letsencrypt.service
[Unit]
Description=Renew the Let's Encrypt TLS certificates for expiring domains
[Service]
Type=simple
ExecStart=/usr/local/bin/letsencrypt-renew
#!/usr/bin/env python3
import glob
from datetime import datetime
import re
from subprocess import Popen, PIPE, STDOUT, call
restart = False
certs = glob.glob('/etc/letsencrypt/live/*/fullchain.pem')
now = datetime.now()
search = re.compile('DNS:([a-z\.]*)')
for cert in certs:
expires = call(['openssl', 'x509', '-in', cert, '-checkend', '2592000'])
if expires:
p2 = Popen('openssl x509 -in ' + cert + ' -text -noout', shell=True, stdin=PIPE, stdout=PIPE, stderr=STDOUT, close_fds=True)
certText = p2.stdout.read().decode("utf-8")
domains = search.findall(certText)
domainArgs = ''
for domain in domains:
domainArgs = domainArgs + ' -d ' + domain
command = './letsencrypt-auto --renew certonly --agree-tos --server https://acme-v01.api.letsencrypt.org/directory --webroot --webroot-path=/etc/letsencrypt/webroot' + domainArgs
success = call(command, shell=True)
if success == 0:
print('Certificates updated')
restart = True
else:
print('Lets Encrypt was unsuccesful')
if restart == True:
call(['systemctl', 'restart', 'nginx'])
I’m wondering if I can make the letsencrypt.service
file restart nginx
depending on the exit code of my python script? But systemd’s documentation seems spread across several sources.
