On one server,
To each of 40 completely different multi-domains,
I would like to install SSL, but is there a limit to the number of installed SSL?
There are no limits to how many certificates you can install, but there is a limit on the rate you can get the certificates. Depending on what you are doing, they may or may not apply to you. You can read about the rate limits here.
There is also a limit on the number of names (domains) you can have in a single certificate. The limit is 100 names. This is because the more names you have, the larger the certificate file, and some browsers don’t like large certificate files.
If you have any questions about these, just reply and someone will be able to help you out.
