Is there a problem with my certs?
My domain is: aewa.org and yukla27.org
I ran this command: certbot certificates
Found the following certs:
Certificate Name: aewa.org-0001
Serial Number: 56e7d5ee07b6436517f15981872386666ff
Key Type: RSA
Domains: aewa.org yukla27.org
Expiry Date: 2025-10-15 07:01:47+00:00 (VALID: 61 days)
Certificate Path: /etc/letsencrypt/live/aewa.org-0001/fullchain.pem
Private Key Path: /etc/letsencrypt/live/aewa.org-0001/privkey.pem
Certificate Name: aewa.org-0002
Serial Number: 591512a4ab621f36a26b55f60e86db7ba30
Key Type: RSA
Domains: aewa.org
Expiry Date: 2025-10-15 07:01:53+00:00 (VALID: 61 days)
Certificate Path: /etc/letsencrypt/live/aewa.org-0002/fullchain.pem
Private Key Path: /etc/letsencrypt/live/aewa.org-0002/privkey.pem
Serial Number: 63cb86ef0e8ab8201180e12a764aaef94f4
Key Type: RSA
Domains: aewa.org www.aewa.org
Expiry Date: 2025-10-15 01:49:06+00:00 (VALID: 61 days)
Certificate Path: /etc/letsencrypt/live/aewa.org/fullchain.pem
Private Key Path: /etc/letsencrypt/live/aewa.org/privkey.pem
Certificate Name: yukla27.org-0001
Serial Number: 699aa166faaf6cb492b50f3053b31eab558
Key Type: RSA
Domains: yukla27.org
Expiry Date: 2025-10-15 07:01:56+00:00 (VALID: 61 days)
Certificate Path: /etc/letsencrypt/live/yukla27.org-0001/fullchain.pem
Private Key Path: /etc/letsencrypt/live/yukla27.org-0001/privkey.pem
Serial Number: 5a2874861206e785d860449af590eb1de63
Key Type: RSA
Domains: www.yukla27.org
Expiry Date: 2025-10-15 07:02:08+00:00 (VALID: 61 days)
Certificate Path: /etc/letsencrypt/live/www.yukla27.org/fullchain.pem
Private Key Path: /etc/letsencrypt/live/www.yukla27.org/privkey.pem
My web server is (include version): apache 2.4.37
The operating system my web server runs on is (include version): Rocky 8.10
My hosting provider, if applicable, is:google web services
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): ver 1.22.0
Besides the fact that some certificates are redundant or could be combined into a single one: why do you think there is a problem with your certs? What problem?
