I have a website with a hosting provider that does not provide shell access. Is it possible to somehow acquire a certificate from Let’s Encrypt without using the client? They are hosted on Microsoft Windows with IIS.
https://gethttpsforfree.com/ will do the trick, but you’ll need to re-do it every 60-90 days.
You could also use one of the alternate clients and use the DNS challenge ( which will ultimately be in the official client as well ). That way you can at least auttomate most of of it.
