Invalid Response, Not 404
forums.mc-sabotage.com
letsencrypt certonly -a webroot --webroot-path=/var/www/html -d forums.mc-sabotage.com
Domain: forums.mc-sabotage.com
Detail: Invalid response from http://forums.mc-sabotage.com/.well-
known/acme-challenge/Jo6wBGjW0EgDIeskFWE5-1l9IxOG-nmoL727lqdOIWg:
"!DOCTYPE html>
html lang=“en”>
head>
meta charset=“utf-8”>
title>MC Sabotage » Forum
meta name=“description”
^^ I took away the ‘<’ at the beginning of each line because Discourse is removing them.
Ubuntu 16.04
I think NGINX (Unsure of the versio)
SoYouStart/OVH
Yes
No
Additional Info: I was able to get my certificate for the original domain, mc-sabotage.com, using this method.
Hi @Lavabird,
Next time, paste the text, select it and click on the button </> so no characters would be removed.
Could you please paste the nginx conf for your domain forums.mc-sabotage.com? Please, paste both server blocks, the one for port 80 where you should have a return directive and the one for port 443.
Cheers,
sahsanu
Is this what you are looking for?
    listen 80;
    server_name forums.mc-sabotage.com;
    return 301 https://forums.mc-sabotage.com$request_uri;
    listen 443 ssl spdy;
    ssl_certificate /etc/letsencrypt/live/forums.mc-sabotage.com/fullchain.pem;
    ssl_certificate_key /etc/letsencrypt/live/forums.mc-sabotage.com/privkey.pem;
        proxy_set_header X_FORWARDED_PROTO https;
        proxy_set_header  X-Forwarded-For $proxy_add_x_forwarded_for;
        proxy_set_header  Host $http_host;
        proxy_set_header  X-Url-Scheme $scheme;
        proxy_redirect    off;
        proxy_max_temp_file_size 0;
        proxy_pass https://forums.mc-sabotage.com:8092/;
        proxy_read_timeout 120;
Yes :wink:
Ok, first, make a backup of the file that you are going to modify... just in case ;)...change your server block for port 80 from this:
    listen 80;
to this:
    listen 80;
    location /.well-known/acme-challenge {
        default_type "text/plain";
        alias   /var/www/html/.well-known/acme-challenge;
Once the new conf is saved, reload nginx:
service nginx reload
or
systemctl reload nginx
And try again to issue the certificate with the same command:
If the new cert is issued pay attention to the last message where letsencrypt will tell you where is the cert saved. Check that your ssl_certificate and ssl_certificate_key directives point to the same dir and reload again nginx.
I hope this helps.
Cheers,
sahsanu
Thanks so much! It worked perfectly :smiley:
Glad you get it working :wink:
