My operating system is (include version): Ubuntu 16.0.4
My hosting provider, if applicable, is: Dedicated server
I can login to a root shell on my machine (yes or no, or I don’t know): I can sudo
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): apache2/AMP
Hi i am trying to get a server control panel (AMP) to work with my new certificate. I setup a subdomain and certificate for this.
e.g amp.mywebsite.co.uk which http redirects via ip:8080 to AMP which runs on ip:8080. I have two live certs one for my subdomain and one for my main domain.
The issue i am having is when i fill out the information required by AMP i get a 503 error when visiting the page via ip or subdomain
Service Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Apache/2.4.18 (Ubuntu) Server at amp.mywebiste.co.uk Port 443
e.g
Webserver.useHTTPS=True
Webserver.CertificatePath=/etc/letsencrypt/live/subdomain.mywebiste.co.uk/cert.pm
Webserver.CertificatePassword=
I have also tried my main domains certificate. Do i need to put anything in password? (I was never asked to set one or set one myself)
I tried attempt to reinstall this existing certificate but i get the error message below:
The selected vhost would conflict with other HTTPS VirtualHosts within Apache. Please select another vhost or add ServerNames to your configuration.
If i use this config leaving both blank it loads and i still have the green lock. Is this secure?
Thanks
