My domain is: kamailio.gcel-legc.ca
I ran this command: sudo certbot --apache -d kamailio.gcel-legc.ca
My web server is (include version): Apache2
I can login to a root shell on my machine (yes or no, or I don't know): No
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot
It's possible it is a firewall issue but we have checked the rules and everything seems okay.
Hi @cam.d286
your output says: It's not ok. Find the blocking instance or a wrong router configuration.
Do I need an externally accessible webserver? Or is it simply just reaching out to the letsencrypt host and not getting a reply. Thanks for the reply!
schoen
January 13, 2021, 5:37am
5
Perhaps more specifically relevant here:
Last updated: Dec 8, 2020 | See all Documentation When you get a certificate from Let’s Encrypt, our servers validate that you control the domain names in that certificate using “challenges,” as defined by the ACME standard. Most of the time, this...
@cam.d286 , in this case the certificate authority is trying to connect to your webserver over the Internet in order to confirm your control over the domain name.
system
Closed
February 12, 2021, 5:38am
6
