Infinite Redirect Loop After Installing Cert
My domain is: imnegs.net
2023.3.20240108-0.amzn2023 I think
Amazon Linux 2023
AWS EC2
Yes
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 2.8.0
Hi, first off I'm a complete noob so please explain as if I know almost nothing. I'm a web dev (that works in a MS environment) and wanted to mess around and try to learn about certs and networking.
Before installing the Let's Encrypt cert, my site was working fine. I was able to go to the domain and see my html (which is just test). After installing, I get the "too many redirects" page in my browser. While searching through the posts here, I found someone that was using check-your-website.server-daten.de, so I ran that and that's how I came to the conclusion that I have an https > https redirect loop. How do I fix this?
Your webserver version is Server: Apache/2.4.58 (Amazon Linux) OpenSSL/3.0.8 (as it self-reports via http headers).
It is likely something bad is in the Apache configuration, which is causing your page to redirect to itself.
If you run this command on your server, it will tell us the configuration and we can help debug it:
sudo apachectl -t -D DUMP_VHOSTS
Thanks for pointing that out!
That command returns "Passing arguments to httpd using apachectl is no longer supported." I've seen other posts with a similar command though:
httpd -t -D DUMP_VHOSTS
So I tried that, and this is the output. Thank you for helping me!
VirtualHost configuration:
*:80                   imnegs.net (/etc/httpd/conf.d/imnegs.net.conf:1)
*:443                  is a NameVirtualHost
         default server imnegs.net (/etc/httpd/conf.d/imnegs.net-le-ssl.conf:2)
         port 443 namevhost imnegs.net (/etc/httpd/conf.d/imnegs.net-le-ssl.conf:2)
         port 443 namevhost ip-172-31-38-50.us-east-2.compute.internal (/etc/httpd/conf.d/ssl.conf:56)
I've been messing around with stuff since posting this topic. I think I should just trash the server at this point and spin up a new one. I'll reply again if I run into the same issue.
If you want to paste the config files from /etc/http/conf.d/, we can try to find out what's wrong with them, but it's up to you :slight_smile:
@TheCC presently I see both Ports 80 & 443 are filtered,
most likely one or more firewalls are the cause.
$ nmap -Pn -p80,443 imnegs.net
Starting Nmap 7.80 ( https://nmap.org ) at 2024-01-25 03:26 UTC
Nmap scan report for imnegs.net (3.144.72.153)
Host is up.
rDNS record for 3.144.72.153: ec2-3-144-72-153.us-east-2.compute.amazonaws.com
PORT    STATE    SERVICE
80/tcp  filtered http
443/tcp filtered https
Nmap done: 1 IP address (1 host up) scanned in 3.10 seconds
Also using the online tool Let's Debug yields these results https://letsdebug.net/imnegs.net/1781846
ANotWorking
ERROR
imnegs.net has an A (IPv4) record (3.144.72.153) but a request to this address over port 80 did not succeed. Your web server must have at least one working IPv4 or IPv6 address.
A timeout was experienced while communicating with imnegs.net/3.144.72.153: Get "http://imnegs.net/.well-known/acme-challenge/letsdebug-test": context deadline exceeded
Trace:
@0ms: Making a request to http://imnegs.net/.well-known/acme-challenge/letsdebug-test (using initial IP 3.144.72.153)
@0ms: Dialing 3.144.72.153
@10000ms: Experienced error: context deadline exceeded
IssueFromLetsEncrypt
ERROR
A test authorization for imnegs.net to the Let's Encrypt staging service has revealed issues that may prevent any certificate for this domain being issued.
3.144.72.153: Fetching http://imnegs.net/.well-known/acme-challenge/zzgQUA63sN_CRrIs45Kt9A58z7xJGCqf-br2wLdevnw: Timeout during connect (likely firewall problem)
They've probably deleted the server now. It was up earlier.
