we are almost there my friend, wen I wrote on the explorer alcalacompra.com it takes me to https://www.alcalacompra.com/ but it doesn't enter the web, If I can I'll ask you something more.
Inside my /etc/hosts y make this modifications
# Default
127.0.0.1 localhost
# Added by me = )
127.0.0.1 alcalacompra.com
127.0.0.1 archivomental.com
# The following lines are desirable for IPv6 capable hosts
::1 ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
ff02::3 ip6-allhosts
so alcalacompra and archivomental should by like that or the right thing is:
Yes sir I will right now! you are the reason that I will make it you know that right he he
Finally my SSL port is listening:
~$ nmap -p 443 --reason www.archivomental.com
Starting Nmap 7.80 ( https://nmap.org ) at 2023-06-15 21:15 CEST
Nmap scan report for www.archivomental.com (127.0.0.1)
Host is up, received syn-ack (0.0013s latency).
rDNS record for 127.0.0.1: localhost
PORT STATE SERVICE REASON
443/tcp open https syn-ack
Nmap done: 1 IP address (1 host up) scanned in 0.53 seconds
Now I will try thank you for your time man. I owe you a big one!
I did nmap from shell bash I can't reach the site too tomorrow I will try now I'm very tired I spend one week with this problem and I wake up at 5:00 am thank you very much for your time and support.
