My domain is: listmonk.sorm.as
I ran this command: trying generate a certificate with nginx and cerbot docker
Requesting a certificate for listmonk.sorm.as and www.listmonk.sorm.as
Domain: listmonk.sorm.as
Type: connection
Detail: 3.**.0.*: Fetching http://listmonk.sorm.as/.well-known/acme-challenge/KAQJ5TOGCRKioIsNG00n2iKRTIfkSTm3BZ_Hiaw4LU8: Timeout during connect (likely firewall problem)
Domain: www.listmonk.sorm.as
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for www.listmonk.sorm.as - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for www.listmonk.sorm.as - check that a DNS record exists for this domain
Reloading nginx ...
2023/04/21 22:35:01 [emerg] 10#10: cannot load certificate "/etc/letsencrypt/live/listmonk.sorm.as/fullchain.pem": BIO_new_file() failed (SSL: error:80000002:system library::No such file or directory:calling fopen(/etc/letsencrypt/live/listmonk.sorm.as/fullchain.pem, r) error:10000080:BIO routines::no such file)
nginx: [emerg] cannot load certificate "/etc/letsencrypt/live/listmonk.sorm.as/fullchain.pem": BIO_new_file() failed (SSL: error:80000002:system library::No such file or directory:calling fopen(/etc/letsencrypt/live/listmonk.sorm.as/fullchain.pem, r) error:10000080:BIO routines::no such file)
root@ip-...:/home/ubuntu/listmonk# sudo cerbot
My web server is (include version): AWS
The operating system my web server runs on is (include version): Ubuntu 22.04.2 LTS
or certbot-auto --version
if you're using Certbot):
