I dont know shit and will pay for help
I see that you got a wildcard certificate for otsmartrecording.net (which I presume was used to cover the internal web sites). The ONLY way to get a wildcard certificate is by using the DNS-01 challenge, which requires access to the DNS records. It's possible that was done manually (the ACME client spit out a challenge string and a human manually added it to the DNS zone) but there had to be some kind of interaction with your DNS zone, either via a human or your ACME client.
i tried doing that but everyone said that they keep saying to me that they were made without modifying the dns records, how?, idk
When you have that discussion, you should refer people to this web page:
And note that for HTTP-01 it says:
  • Let’s Encrypt doesn’t let you use this challenge to issue wildcard certificates.
And for DNS-01 it says:
  • You can use this challenge to issue certificates containing wildcard domain names.
I see the nameservers for otsmartrecording.net are run by Cloudflare, it's possible they did the magic on the DNS zone.
