I can not create a certificate when using --webroot plugin
We are not done testing :frowning:
go ahead. .sorry
Ok that test passed - Hi back!
Now we need to simulate a more accurate challenge request.
Make the challenge path:
mkdir -p /var/www/scribblersathome/.well-known/acme-challenge/
then create the test file:
echo "test#2" > /var/www/scribblersathome/.well-known/acme-challenge/test2-file
then try it from the Internet:
http://scribblersathome.com/.well-known/acme-challenge/test2-file
curl https://scribblersathome.com//.well-known/acme-ch
allenge/test2-file
test#2
 curl -Ii https://scribblersathome.com//.well-known/acm
HTTP/2 200
etag: "7-63cb06df-89a24;;;"
last-modified: Fri, 20 Jan 2023 21:25:51 GMT
content-length: 7
accept-ranges: bytes
date: Fri, 20 Jan 2023 21:32:09 GMT
server: LiteSpeed
alt-svc: h3=":443"; ma=2592000, h3-29=":443"; ma=2592000, h3-Q050=":443"
; ma=2592000, h3-Q046=":443"; ma=2592000, h3-Q043=":443"; ma=2592000, qu
ic=":443"; ma=2592000; v="43,46"
The problem is that you tested HTTPS - and that works.
But the request is via HTTP - and that fails!
curl https://scribblersathome.com/.well-known/acme-challenge/test2-file
test#2
curl -Ii http://scribblersathome.com/.well-known/acme-challenge/test2-file
HTTP/1.1 404 Not Found
date: Fri, 20 Jan 2023 21:38:13 GMT
server: LiteSpeed
connection: Keep-Alive
For the /.well-known/acme-challenge/ path, your HTTP isn't redirecting to HTTPS indeed, but other paths do. So some code in your OpenLiteSpeed must cause this specific behaviour for /.well-known/acme-challenge/ paths.
It only "worked" because that "double slash" did not match the exact challenge path and it was redirected to HTTPS [which works].
The correct path fails.
Because...
There is some code in the HTTP server block to handle challenge requests from some other root path [NOT /var/www/scribblersathome].
Can you try again please??
Bingo!
curl http://scribblersathome.com/.well-known/acme-challenge/test2-file
test#2
Now you can delete the test files.
I'd leave that path there OR it will have to be created and deleted (by certbot) for each renewal request.
It was not exactly a problem with the path, I only have one DocumentRoot path, the vhost need to add the listener for http/80 port. When you told me about http vs https I checked and added this listener.
Gracias Rudy y Osiris.
Then the HTTP was being served by the default block.
Which simply sent all HTTP to HTTPS [except challenge locations - which it sent elsewhere].
Another reason to keep port 80 open and each server block using it.
Cheers from Miami :beers:
