rakrock
January 19, 2019, 10:32am
1
Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. https://crt.sh/?q=example.com ), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is: www.xyz.com
I ran this command: sudo -H ./letsencrypt-auto certonly --standalone --renew-by-default -d xyz.com -d www.xyz.com
It produced this output: WARNING: couldn’t find Python 2.7+ to check for updates.
./letsencrypt-auto: line 920: python3: command not found
My web server is (include version): CentOS 6.9
The operating system my web server runs on is (include version): CentOS 6.9
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): No.
And on browser i get this error message : NET::ERR_CERT_DATE_INVALID
_az
January 19, 2019, 10:58am
2
Weird. What’s this show:
command -v python3
which python3
python3 -V
Maybe you have a dead symlink to an uninstalled version of Python.
rakrock
January 19, 2019, 12:12pm
3
i have already installed the Python3 but still i get
i have updated but still facing this error…
for this any another solution???
What’s the output of the commands in @_az ’s post?
I get this after renew the certificate, and i have check in my system have 2.7 Python and i have
also installed Python 3.0 but still get this error
rg305
January 21, 2019, 6:31am
6
I would try: running the actual file and from the same directory
find / -name letsencrypt-auto
and
find / -name certbot-auto
cd
{to the directory of the file found above - if that returns a link, then: to the actual file location}
then [whichever actual file name was found]
sudo ./letsencrypt-auto …
or
sudo ./certbot-auto …
still get same issue…
./letsencrypt-auto: python3: command not found
DO i need Pthon 3 or not ?
_az
January 21, 2019, 7:05am
8
You don’t need Python 3, but if you have a dead symlink to the python3 binary, it will fail in that way.
That’s why I asked you to post the output of those commands, because it could help answer your question, but you ignored me.
_az:
command -v python3
which python3
python3 -V
i get this when i check phyton version
python -V
Python 2.7.6
Python 3 not have in my system
_az
January 21, 2019, 7:26am
10
Please post the verbatim output of all 3 commands, exactly how I typed them. I don’t care if they fail or not.
rakrock
11
do i need Installed Python 3 in my system,
If, Yes than i think my other thinks are hamper.
rakrock
January 21, 2019, 8:11am
13
[root@0000 letsencrypt]# sudo -H ./letsencrypt-auto certonly --standalone --renew-by-default -d billing.xyz.co.in -d www.billing.xyz.co.in
I get above when i renew , what i do…
system
Closed
February 20, 2019, 8:11am
14
