Hello
I add this record to DNS of my domain:
Active Type Name Data Priority TTL
Yes A api.glinboy.com myServerIP 0 3600
Yes A apps.glinboy.com myServerIP 0 3600
and this for glinboy.ir:
Yes A api.glinboy.ir myServerIP 0 3600
Yes A apps.glinboy.ir myServerIP 0 3600
but after run command
sudo ./certbot-auto certonly -w /var/www/glinboy.com/ssl -d glinboy.com -d glinboy.ir -d apps.glinboy.com -d apps.glinboy.ir -d api.glinboy.com -d api.glinboy.ir
I got error that DNS,
This is Error:
Failed authorization procedure. apps.glinboy.ir (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: NXDOMAIN looking up A for apps.glinboy.ir, api.glinboy.ir (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: NXDOMAIN looking up A for api.glinboy.ir, apps.glinboy.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: NXDOMAIN looking up A for apps.glinboy.com, api.glinboy.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: NXDOMAIN looking up A for api.glinboy.com
Domain: apps.glinboy.ir
Type: connection
Detail: DNS problem: NXDOMAIN looking up A for apps.glinboy.ir
Domain: api.glinboy.ir
Type: connection
Detail: DNS problem: NXDOMAIN looking up A for api.glinboy.ir
Domain: apps.glinboy.com
Type: connection
Detail: DNS problem: NXDOMAIN looking up A for apps.glinboy.com
Domain: api.glinboy.com
Type: connection
Detail: DNS problem: NXDOMAIN looking up A for api.glinboy.com
Note: At past i have similar problem with DNS record that can’t found any solution; I try to add a CNAME DNS record for Openshift application to handle my subdomain to app but this never work!!! (this tutorial: blog.openshift.com/domain-names-and-ssl-in-the-openshift-web-console/)
I think my DNS server has error but i can’t found this
Info:
I Installed Ispconfig 3.1.5 on Ubuntu 16.04
Can I generate SSL cert for this domains and sub-domains on another way?
