My domain is: sandbarsoftware.ie
I ran this command on the browser: https://sandbarsoftware.ie
The I ran this URL: https://www.sandbarsoftware.ie
Warning: Potential Security Risk Ahead
Firefox Developer Edition detected a potential security threat and did not continue to www.sandbarsoftware.ie. If you visit this site, attackers could try to steal information like your passwords, emails, or credit card details.
What can you do about it?
The issue is most likely with the website, and there is nothing you can do to resolve it. You can notify the website’s administrator about the problem.
Learn more…
Websites prove their identity via certificates. Firefox Developer Edition does not trust this site because it uses a certificate that is not valid for www.sandbarsoftware.ie. The certificate is only valid for sandbarsoftware.ie.
Error code: SSL_ERROR_BAD_CERT_DOMAIN
View Certificate
My web server is (include version): Apache/2.4.52 (Ubuntu)
Server built: 2023-03-08T17:32:01
The operating system my web server runs on is (include version): Ubuntu 22.04.2 LTS
My hosting provider, if applicable, is: OVH
I can login to a root shell on my machine (yes or no, or I don't know): YES
NO CONTROL PANEL IS USED WITH MY WEBSITE AS MY SERVER IS A VPS.
HOWEVER I DO USE THE OVH VPS CONTROL PANEL TO MANAGE MY VPS AND ITS ASSOCIATED DOMAIN NAME.
I CONFIGURED SEPARATE "A RECORDS" FOR BOTH MY DOMAIN NAME AND ITS WWW SUB-DOMAIN NAME. THE WWW SUB-DOMAIN WAS ONLY DONE TODAY AND IT WILL TAKE 1-2 DAYS TO PROPAGATE, I'M TOLD. THIS MAY OR MAY NOT HAVE RELEVANCE TO THIS ISSUE.
or certbot-auto --version
if you're using Certbot): 1.21.0
My website's .conf file is:
<VirtualHost *:80>
# specifies what hostname must appear in the request's Host: header to
ServerName sandbarsoftware.ie
ServerAlias www.sandbarsoftware.ie
ServerAdmin xx@yyyyyyyyyyyyyyyy
DocumentRoot /var/www/html/sandbarsoftware.ie
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
RewriteEngine on
#RewriteCond %{SERVER_NAME} =sandbarsoftware.ie
RewriteCond %{SERVER_NAME} ^(www\.)?sandbarsoftware.ie$
</VirtualHost>
Notice I commented out the Certbot written RewriteCond and inserted one that I thought would embrace www sub-domains also.
But there is no change.
I also removed old self-signed SSLCertificate and SSLCertificateKey file pointer values from the default configuration file, /etc/apache2/sites-available/default-ssl.conf:
<IfModule mod_ssl.c>
<VirtualHost _default_:443>
# modules, e.g.
# SSL Engine Switch:
# Enable/Disable SSL for this virtual host.
#SSLEngine on
# A self-signed (snakeoil) certificate can be created by installing
# the ssl-cert package. See
# /usr/share/doc/apache2/README.Debian.gz for more info.
# If both key and certificate are stored in the same file, only the
# SSLCertificateFile directive is needed.
# Server Certificate Chain:
# Point SSLCertificateChainFile at a file containing the
# concatenation of PEM encoded CA certificates which form the
# certificate chain for the server certificate. Alternatively
# the referenced file can be the same as SSLCertificateFile
# when the CA certificates are directly appended to the server
# certificate for convinience.
#SSLCertificateChainFile /etc/apache2/ssl.crt/server-ca.crt
# Certificate Authority (CA):
# Set the CA certificate verification path where to find CA
# certificates for client authentication or alternatively one
# huge file containing all of them (file must be PEM encoded)
# Note: Inside SSLCACertificatePath you need hash symlinks
# to point to the certificate files. Use the provided
# Makefile to update the hash symlinks after changes.
#SSLCACertificatePath /etc/ssl/certs/
#SSLCACertificateFile /etc/apache2/ssl.crt/ca-bundle.crt
# Certificate Revocation Lists (CRL):
# Set the CA revocation path where to find CA CRLs for client
# authentication or alternatively one huge file containing all
# of them (file must be PEM encoded)
# Note: Inside SSLCARevocationPath you need hash symlinks
#SSLCARevocationPath /etc/apache2/ssl.crl/
#SSLCARevocationFile /etc/apache2/ssl.crl/ca-bundle.crl
# Client Authentication (Type):
# Client certificate verification type and depth. Types are
# none, optional, require and optional_no_ca. Depth is a
# number which specifies how deeply to verify the certificate
# issuer chain before deciding the certificate is not valid.
#SSLVerifyClient require
#SSLVerifyDepth 10
# SSL Engine Options:
# Set various options for the SSL engine.
# o FakeBasicAuth:
# Translate the client X.509 into a Basic Authorisation. This means that
# the standard Auth/DBMAuth methods can be used for access control. The
# user name is the `one line' version of the client's X.509 certificate.
# Note that no password is obtained from the user. Every entry in the user
# file needs this password: `xxj31ZMTZzkVA'.
# o ExportCertData:
# This exports two additional environment variables: SSL_CLIENT_CERT and
# SSL_SERVER_CERT. These contain the PEM-encoded certificates of the
# server (always existing) and the client (only existing when client
# authentication is used). This can be used to import the certificates
# into CGI scripts.
# o StdEnvVars:
# This exports the standard SSL/TLS related `SSL_*' environment variables.
# Per default this exportation is switched off for performance reasons,
# because the extraction step is an expensive operation and is usually
# useless for serving static content. So one usually enables the
# exportation for CGI and SSI requests only.
# o OptRenegotiate:
# This enables optimized SSL connection renegotiation handling when SSL
# directives are used in per-directory context.
#SSLOptions +FakeBasicAuth +ExportCertData +StrictRequire
<FilesMatch "\.(cgi|shtml|phtml|php)$">
SSLOptions +StdEnvVars
</FilesMatch>
<Directory /usr/lib/cgi-bin>
</Directory>
# SSL Protocol Adjustments:
# The safe and default but still SSL/TLS standard compliant shutdown
# approach is that mod_ssl sends the close notify alert but doesn't wait for
# the close notify alert from client. When you need a different shutdown
# approach you can use one of the following variables:
# o ssl-unclean-shutdown:
# This forces an unclean shutdown when the connection is closed, i.e. no
# SSL close notify alert is send or allowed to received. This violates
# the SSL/TLS standard but is needed for some brain-dead browsers. Use
# this when you receive I/O errors because of the standard approach where
# mod_ssl sends the close notify alert.
# o ssl-accurate-shutdown:
# This forces an accurate shutdown when the connection is closed, i.e. a
# SSL close notify alert is send and mod_ssl waits for the close notify
# alert of the client. This is 100% SSL/TLS standard compliant, but in
# practice often causes hanging connections with brain-dead browsers. Use
# this only for browsers where you know that their SSL implementation
# works correctly.
# Notice: Most problems of broken clients are also related to the HTTP
# keep-alive facility, so you usually additionally want to disable
# keep-alive for those clients, too. Use variable "nokeepalive" for this.
# Similarly, one has to force some clients to use HTTP/1.0 to workaround
# their broken HTTP/1.1 implementation. Us<IfModule mod_ssl.c>
# modules, e.g.
#SSLEngine on
#SSLVerifyDepth 10
# o FakeBasicAuth:
# o ExportCertData:
# into CGI scripts.
# o StdEnvVars:
# o OptRenegotiate:
</FilesMatch>
</Directory>
# works correctly.
# their broken HTTP/1.1 implementation. Use variables "downgrade-1.0" and
# "force-response-1.0" for this.
# BrowserMatch "MSIE [2-6]" \
# nokeepalive ssl-unclean-shutdown \
# downgrade-1.0 force-response-1.0
</VirtualHost>
</IfModule>e variables "downgrade-1.0" and
</VirtualHost>
</IfModule>
I tried inserting the new actual Certbot SSL Certificate pointers to the above default file.
No change either !
Any ideas what's wrong ?
Or should I just wait for the www sub-domain A Record to propagate as an alias to the VPS IP address ?
