Https://www.assentushealth.com/ not working
https://www.assentushealth.com/
Has been working for a few years but now something is wrong with the cert. I tried redo it, but it says "not ready for renewal". There are others certs on the same server that work just fine.
command:
/snap/bin/certbot renew --allow-subset-of-names
Logs:
q2024-01-21 08:08:04,292:DEBUG:certbot._internal.display.obj:Notifying user: Processing /etc/letsencrypt/renewal/assentushealth.com.conf
2024-01-21 08:08:04,435:DEBUG:certbot.ocsp:OCSP response for certificate /etc/letsencrypt/archive/assentushealth.com/cert28.pem is signed by the certificate's issuer.
2024-01-21 08:08:04,438:DEBUG:certbot.ocsp:OCSP certificate status for /etc/letsencrypt/archive/assentushealth.com/cert28.pem is: OCSPCertStatus.GOOD
2024-01-21 08:08:05,015:DEBUG:certbot._internal.display.obj:Notifying user: /etc/letsencrypt/live/assentushealth.com/fullchain.pem expires on 2024-03-31 (skipped)
2024-01-21 15:52:04,378:DEBUG:certbot._internal.display.obj:Notifying user: Processing /etc/letsencrypt/renewal/assentushealth.com.conf
2024-01-21 15:52:04,581:DEBUG:certbot.ocsp:OCSP response for certificate /etc/letsencrypt/archive/assentushealth.com/cert28.pem is signed by the certificate's issuer.
2024-01-21 15:52:04,582:DEBUG:certbot.ocsp:OCSP certificate status for /etc/letsencrypt/archive/assentushealth.com/cert28.pem is: OCSPCertStatus.GOOD
2024-01-21 15:52:05,270:DEBUG:certbot._internal.display.obj:Notifying user: /etc/letsencrypt/live/assentushealth.com/fullchain.pem expires on 2024-03-31 (skipped)
That's to be expected, as it's expiry date is way in the future.
What is your exact issue? Also:
When you opened this thread in the Help section, you should have been provided with a questionnaire. Maybe you didn't get it somehow (which is weird), or you've decided to delete it. In any case, all the answers to this questionnaire are required:
Hi @hal1,
Here is a list of issued certificates crt.sh | assentushealth.com, the latest being 2024-01-01.
That one is unique compared to the rest of the list in that it only has the
Matching Identities of assentushealth.com; all the previous issued certificates have
Matching Identities of assentushealth.com and www.assentushealth.com.
You can check the currently being server certificate for assentushealth.com https://decoder.link/sslchecker/assentushealth.com/443 and is OK.
You can check the currently being server certificate for www.assentushealth.com
https://decoder.link/sslchecker/www.assentushealth.com/443
and see the " Hostname: Doesn't match Common Name or/and SANs".
Interesting! Wonder how that happened? Is that whats causing it?
host www.assentushealth.com
www.assentushealth.com is an alias for assentushealth.com.
assentushealth.com has address 34.70.17.25
Someone requested a certificate that only contains that name instead of renewing the existing certificate. If you want to use both names, the certificate must contain them both. Obtain a new one that contains both names and renew when it is due.
Probably that.
Or, someone issued the below command and there was a failure validating one of the domain names. In that case the cert would be issued but without the failing name.
The --allow-subset-of-names should only be used in carefully controlled circumstances and its results confirmed manually
Fixed now. I think was that it was a very old syntax when it was created. The syntax contained both names originally. Thanks!
