Https URL Rewrite - some traffic, not all
I’ve added a couple more proxy redirects for couchpotato and sonarr, they are only working if i use port 80. If i try and use ssl, I just get taken to the first default countdown page. Also is it possible to get a “not found” page rather than defaulting to the first page?
EDIT: ODDLY enough, just checked, and both these pages are showing as https pages?!
map $http_upgrade $connection_upgrade {
default upgrade;
’’ close;
# Redirect all http traffic to https
    listen 80;
    server_name mydomain.co.uk;
    listen 443 ssl;
    root /config/www/countdown;
    index index.html index.htm index.php;
    server_name countdown.mydomain.co.uk;
    ssl on;
    ssl_certificate /config/keys/letsencrypt/fullchain.pem;
    ssl_certificate_key /config/keys/letsencrypt/privkey.pem;
    ssl_dhparam /config/nginx/dhparams.pem;
    ssl_ciphers 'ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA';
    ssl_prefer_server_ciphers on;
      try_files $uri $uri/ =404;
    listen 443 ssl;
    root /config/www/;
    server_name blog.mydomain.co.uk;
    ssl on;
# Home Assistant
    listen 443 ssl;
    root /config/www;
    server_name ha.mydomain.co.uk;
    ssl on;
    client_max_body_size 0;
    proxy_buffering off;
        proxy_pass http://192.168.12.202:8123/;
        proxy_set_header Host $host;
        proxy_redirect http:// https://;
        proxy_http_version 1.1;
        proxy_set_header Connection $connection_upgrade;
# Emby
    listen 443 ssl;
    root /config/www;
    server_name media.mydomain.co.uk;
    ssl on;
        proxy_pass http://192.168.10.101:8096/;
# AD
    listen 443 ssl;
    root /config/www;
    server_name ad.mydomain.co.uk;
    ssl on;
        proxy_pass http://192.168.12.203:5050/;
# Stats
    listen 443 ssl;
    root /config/www;
    server_name stats.mydomain.co.uk;
    ssl on;
        proxy_pass http://192.168.12.204:3000/;
#qbit
    listen 80;
    root /config/www;
    server_name qbit.mydomain.co.uk;
        proxy_pass http://192.168.12.217:8080/;
# deluge
    listen 80;
    root /config/www;
    server_name deluge.mydomain.co.uk;
        proxy_pass http://192.168.12.216:8112/;
#Sonarr
    listen 80;
    root /config/www;
    server_name sonarr.mydomain.co.uk;
        proxy_pass http://192.168.12.218:8989/;
#Potato
    listen 80;
    root /config/www;
    server_name potato.mydomain.co.uk;
        proxy_pass http://192.168.12.219:5050/;
#NextCloud
    listen 443 ssl;
    root /config/www;
    server_name nextcloud.mydomain.co.uk;
    ssl on;
        proxy_pass https://192.168.12.220:443/;
Thanks.
So should I remove each one of these lines from my file?
There is no “couchpotato” in your config - so it will default to the first host.
The “sonarr” is only configured for port 80 - you need a matching port 443 config.
"Yes" and "No"
By tricking the system into serving the first block when unmatched - which you configure to point to a document root that only serves the one page saying "NOT FOUND", you can achieve that goal.
But there is no way that I know of to NOT serve a page when the domain is not matched.
sorry the name it matches is potato… both this and sonarr are loading, i did have both the sonarr and potato block set the same as stats, with the server name and proxy_pass address and ports changed to the correct details.
Ideally I’d like to get deluge and qBit running over 443/https as well as potato and sonarr, but they only seem to work with http/80
Ok as for the not found, I get that, I need to create a notfound.html page and create a new block at the begining, that serves that page.
correct.
As for the “potato” and “sonarr” not being served by https, they are not included in any https (443) block.
In essence, each name will need an http (80) and an https (443) block.
And also the additional first blocks for “not found” domains.
So would each block look like this?
    listen 80;
    listen 443 ssl;
    ssl on;
no.
They need to be separate blocks.
one small one for 80 (just to redirect).
and the larger one for 443.
So, is this correct?
default upgrade;
’’ close;
#Countdown
    listen 80;
#Countdown
    listen 443 ssl;
    ssl on;
#Blog
    listen 80;
#Blog
    listen 443 ssl;
    root /config/www/;
    ssl on;
#HomeAssistant
    listen 80;
#HomeAssistant
    listen 443 ssl;
    root /config/www;
    ssl on;
#Emby
    listen 80;
#Emby
    listen 443 ssl;
    root /config/www;
    ssl on;
#AppDaemon
    listen 80;
#AppDaemon
    listen 443 ssl;
    root /config/www;
    ssl on;
#Stats
    listen 80;
#Stats
    listen 443 ssl;
    root /config/www;
    ssl on;
#qBit
    listen 80;
#qBit
    listen 443 ssl;
    root /config/www;
    ssl on;
# deluge
    listen 80;
#Deluge
    listen 443 ssl;
    root /config/www;
    ssl on;
#Sonarr
    listen 80;
#Sonarr
    listen 443 ssl;
    root /config/www;
    ssl on;
#Potato
    listen 80;
#Potato
    listen 443 ssl;
    root /config/www;
    ssl on;
#NextCloud
    listen 80;
#NextCloud
    listen 443 ssl;
    root /config/www;
    ssl on;
Yes, that is the idea.
Now you just need the additional (80+443) first blocks for “not found”/default domains.
Unless you want “countdown” to handle those.
Great! Thanks you so much! Out of interest, can i get rid of the root and index lines on the URL re-write blocks, or do they need to be there, even for a rewrite?
Where?
I don't see them in the 80 block - only in the 443 blocks.
they are in the 443 blocks, sorry not url re-write, the 443 sections are mainly reverse proxys.
Oh!
Yes.
When you are redirecting the entire block, you don’t need root nor index.
NOTE: You may need to handle the /.well-known/acme-challenge/ folder cert renewal requests.
I don’t see how you are doing that now.
As is, they would proxy through to the back-end system.
Something like this should work:
root /location/to/acme-challenges/; #a common folder location you create
try_files $uri =404;
The challenge requests/responses are not secret information and not likely to generate a similarly named file and generally get deleted soon after, so they can share the same location.
I’m lost on that bit i’m afraid… sorry.
location / #will proxy ALL request to the proxied site:
When a cert renewal comes (in 2 months), it will request a file like:
http://your.domain/.well-known/acme-challenge/ns94grffonh,s6b48brgwsj94gr #some 40 digit named file
That request will be redirected to https:
https://your.domain/.well-known/acme-challenge/ns94grffonh,s6b48brgwsj94gr
And that renewal request will be proxied and served by:
https://192.168.12.220:443/.well-known/acme-challenge/ns94grffonh,s6b48brgwsj94gr
Which will error out 404 not found.
If you don’t handle it properly - locally.
Certificate renewal requests should NOT be proxied to another system.
They need to be handled locally (to where the certbot runs).
That says direct all requests to the challenge folder to the local directory (you create).
ok, i think i understand. however it is only the reverse proxy that handles the certificate, nothing else has the certificate on it, (most of the back end systems are setup ussig http, and the https is offloaded at the letsencrypt docker in unraid.) or i have i mis-understood?
Where does CERTBOT run?
That is where you handle the challenge requests.
Ideally in the http blocks (no need to redirect to https).
Or even above all blocks.
In the global settings, you can make one single ALIAS change that would be followed systemwide.
For Apache2:
#Load alias module - if not already loaded
LoadModule alias_module modules/mod_alias.so
Then use something like this in the “main” http block:
<IfModule alias_module>
Alias /.well-known/acme-challenge/ /location/to/acme-challenges/
</IfModule>
For NGINX:
It seems NGINX doesn’t do global aliases: https://stackoverflow.com/questions/21908833/nginx-doesnt-allow-a-global-location-directive
The certbot runs in the docker, which is where NGINX is running and doing the reverse proxying.
