Hello, I have been struggling to get my website running with my certificate, it works with http but not with https, so my index.html in var/www/html can be found. I've tried pretty much everything I found and the page just wont load. This is my first time setting up a server and don't understand what most of the errors in the errorlog below mean.
I have a redirect from http to https, I only did that after making sure the http is working fine, taking out the redirect and loading the http works fine.
I am not hosting on Strato, we only got the domain and www subdomain from there, I am hosting on BWCloud(a cloud platform developed and operated by the government of Baden-WĂĽrttemberg in Germany). It offers a range of cloud services and infrastructure for public sector organizations, such as government agencies and educational institutions, students at our university use it on a regular and a friend of mine has no issues with it, the only difference is that he uses apache, but that is very unlikely to be the reason.
SSL Labs only respons with "Assessment failed: Unable to connect to the server" but I don't get why.
If you need any more information let me know. Thank you in advance.
My Port 443 and 80 are open, "sudo ss -tulpn | grep LISTEN" outputs
tcp LISTEN 0 151 127.0.0.1:3306 0.0.0.0:* users:(("mysqld",pid=821,fd=23))
tcp LISTEN 0 511 0.0.0.0:80 0.0.0.0:* users:(("nginx",pid=15372,fd=8),("nginx",pid=15371,fd=8),("nginx",pid=15370,fd=8))
tcp LISTEN 0 4096 127.0.0.53%lo:53 0.0.0.0:* users:(("systemd-resolve",pid=658,fd=13))
tcp LISTEN 0 128 0.0.0.0:22 0.0.0.0:* users:(("sshd",pid=762,fd=3))
tcp LISTEN 0 511 0.0.0.0:443 0.0.0.0:* users:(("nginx",pid=15372,fd=7),("nginx",pid=15371,fd=7),("nginx",pid=15370,fd=7))
tcp LISTEN 0 70 127.0.0.1:33060 0.0.0.0:* users:(("mysqld",pid=821,fd=21))
tcp LISTEN 0 511 [::]:80 [::]:* users:(("nginx",pid=15372,fd=9),("nginx",pid=15371,fd=9),("nginx",pid=15370,fd=9))
tcp LISTEN 0 128 [::]:22 [::]:* users:(("sshd",pid=762,fd=4))
tcp LISTEN 0 511 [::]:443 [::]:* users:(("nginx",pid=15372,fd=6),("nginx",pid=15371,fd=6),("nginx",pid=15370,fd=6))
The firewall allows access from anywhere, I had it set to inactive before and that didn't change anything, "sudo ufw status" outputs
Status: active
To Action From
Nginx HTTPS ALLOW Anywhere
22/tcp ALLOW Anywhere
Nginx Full ALLOW Anywhere
443/tcp ALLOW Anywhere
Nginx HTTPS (v6) ALLOW Anywhere (v6)
22/tcp (v6) ALLOW Anywhere (v6)
Nginx Full (v6) ALLOW Anywhere (v6)
443/tcp (v6) ALLOW Anywhere (v6)
The ownership of my sites available and sites enabled is set to www-data
"sudo nginx -t" responds with
brainknots.de / www.brainknots.de
nginx/1.18.0 (Ubuntu)
Ubuntu 20.04
I got the domain from:
Strato
I can login to a root shell on my machine:
Yes
I'm using a control panel to manage my site:
No
The version of my client is:
certbot 0.40.0
My brainknots.de.conf in my sites available is linked to the sites enabled and looks like this
root /var/www/html;
server_name brainknots.de www.brainknots.de;
index index.html index.htm;
# RSA certificate
ssl_certificate /etc/letsencrypt/live/brainknots.de/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/brainknots.de/privkey.pem; # managed by Certbot
# Redirect non-https traffic to https
if ($scheme != "https") {
} # managed by Certbot
if ($host = www.brainknots.de) {
if ($host = brainknots.de) {
listen 80 default_server;
return 301 https://$server_name$request_uri;
My nginx.conf looks like this:
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
# server_tokens off;
server_names_hash_bucket_size 64;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
error_log /var/log/nginx/error.log debug;
#gzip on;
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# Virtual Host Configs
#mail {
# # See sample authentication script at:
# # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
# # auth_http localhost/auth.php;
# # pop3_capabilities "TOP" "USER";
# # imap_capabilities "IMAP4rev1" "UIDPLUS";
# server {
# listen localhost:110;
# protocol pop3;
# proxy on;
# server {
# listen localhost:143;
# protocol imap;
# proxy on;
cat /var/log/nginx/error.log
(I only put the last few lines)
2023/06/23 19:52:26 [debug] 15371#15371: *353 http write filter: l:1 f:0 s:384
2023/06/23 19:52:26 [debug] 15371#15371: *353 http write filter limit 0
2023/06/23 19:52:26 [debug] 15371#15371: *353 writev: 384 of 384
2023/06/23 19:52:26 [debug] 15371#15371: *353 http write filter 0000000000000000
2023/06/23 19:52:26 [debug] 15371#15371: *353 http copy filter: 0 "/?"
2023/06/23 19:52:26 [debug] 15371#15371: *353 http finalize request: 0, "/?" a:1, c:2
2023/06/23 19:52:26 [debug] 15371#15371: *353 event timer add: 4: 5000:293377440
2023/06/23 19:52:26 [debug] 15371#15371: *353 http request count:2 blk:0
2023/06/23 19:52:26 [debug] 15371#15371: *353 http run request: "/?"
2023/06/23 19:52:26 [debug] 15371#15371: *353 http read discarded body
2023/06/23 19:52:26 [debug] 15371#15371: *353 recv: eof:0, avail:-1
2023/06/23 19:52:26 [debug] 15371#15371: *353 recv: fd:4 20 of 20
2023/06/23 19:52:26 [debug] 15371#15371: *353 recv: avail:0
2023/06/23 19:52:26 [debug] 15371#15371: *353 http finalize request: -4, "/?" a:1, c:1
2023/06/23 19:52:26 [debug] 15371#15371: *353 set http keepalive handler
2023/06/23 19:52:26 [debug] 15371#15371: *353 http close request
2023/06/23 19:52:26 [debug] 15371#15371: *353 http log handler
2023/06/23 19:52:26 [debug] 15371#15371: *353 free: 000055C90724F6B0, unused: 1
2023/06/23 19:52:26 [debug] 15371#15371: *353 free: 000055C907225E40, unused: 2442
2023/06/23 19:52:26 [debug] 15371#15371: *353 free: 000055C9072061B0
2023/06/23 19:52:26 [debug] 15371#15371: *353 hc free: 0000000000000000
2023/06/23 19:52:26 [debug] 15371#15371: *353 hc busy: 0000000000000000 0
2023/06/23 19:52:26 [debug] 15371#15371: *353 tcp_nodelay
2023/06/23 19:52:26 [debug] 15371#15371: *353 reusable connection: 1
2023/06/23 19:52:26 [debug] 15371#15371: *353 event timer del: 4: 293377440
2023/06/23 19:52:26 [debug] 15371#15371: *353 event timer add: 4: 65000:293437440
2023/06/23 19:52:26 [debug] 15371#15371: *353 post event 000055C907282A50
2023/06/23 19:52:26 [debug] 15371#15371: *353 delete posted event 000055C907282A50
2023/06/23 19:52:26 [debug] 15371#15371: *353 http keepalive handler
2023/06/23 19:52:26 [debug] 15371#15371: *353 malloc: 000055C9072061B0:1024
2023/06/23 19:52:26 [debug] 15371#15371: *353 recv: eof:0, avail:0
2023/06/23 19:52:26 [debug] 15371#15371: *353 recv: eof:1, avail:-1
2023/06/23 19:52:26 [debug] 15371#15371: *353 recv: fd:4 0 of 1024
2023/06/23 19:52:26 [info] 15371#15371: *353 client 162.19.180.189 closed keepalive connection
2023/06/23 19:52:26 [debug] 15371#15371: *353 close http connection: 4
2023/06/23 19:52:26 [debug] 15371#15371: *353 event timer del: 4: 293437440
2023/06/23 19:52:26 [debug] 15371#15371: *353 reusable connection: 0
2023/06/23 19:52:26 [debug] 15371#15371: *353 free: 000055C90721D9B0, unused: 136
If I run "sudo certbot renew --dry-run" I get no errors as you can see here
Processing /etc/letsencrypt/renewal/brainknots.de.conf
Attempting to parse the version 2.6.0 renewal configuration file found at /etc/letsencrypt/renewal/brainknots.de.conf with version 0.40.0 of Certbot. This might not work.
http-01 challenge for brainknots.de
http-01 challenge for www.brainknots.de
new certificate deployed with reload of nginx server; fullchain is
/etc/letsencrypt/live/brainknots.de/fullchain.pem (success)
And running "sudo certbot certificates" outputs
Found the following certs:
Certificate Name: brainknots.de
Domains: brainknots.de www.brainknots.de
Expiry Date: 2023-09-17 17:00:49+00:00 (VALID: 85 days)
Certificate Path: /etc/letsencrypt/live/brainknots.de/fullchain.pem
Private Key Path: /etc/letsencrypt/live/brainknots.de/privkey.pem
"nslookup brainknots.de" gives me
Server: 212.227.123.16
Address: 212.227.123.16#53
Non-authoritative answer:
Address: 192.52.42.17
Nginx is also running as shown below
ubuntu@brainknots2:/etc/nginx$ sudo nginx status
nginx: invalid option: "status"
ubuntu@brainknots2:/etc/nginx$ systemctl status nginx
â—Ź nginx.service - A high performance web server and a reverse proxy server
Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2023-06-21 14:23:37 UTC; 2 days ago
Docs: man:nginx(8)
Main PID: 15370 (nginx)
Tasks: 3 (limit: 4662)
Memory: 6.5M
CGroup: /system.slice/nginx.service
├─15370 nginx: master process /usr/sbin/nginx -g daemon on; master_process on;
├─31550 nginx: worker process
└─31551 nginx: worker process
Jun 21 14:23:37 brainknots2 systemd[1]: Starting A high performance web server and a reverse proxy server...
Jun 21 14:23:37 brainknots2 systemd[1]: Started A high performance web server and a reverse proxy server.
