Please show the certbot command line you ran.
all I did was run this:
certbot --apache
then I did the numbers of the sites I wanted (3, 4 in my case).
then for the redirect, I entered 2.
Try 3,4 then 1.
You already have the redirection taken care of.
[whichever number doesn’t ask it to add redirection for you]
Then show the error message, if any.
[however insignificant the message may seem - please include all shown]
Still doesn’t work.
But the log looks normal.
1: asite.com
2: www.asite.com
3: mainsite.com
4: www.mainsite.com
blank to select all options shown (Enter ‘c’ to cancel): 3, 4
Cert not yet due for renewal
You have an existing certificate that has exactly the same domains or certificate name you requested and isn’t close to expiry.
(ref: /etc/letsencrypt/renewal/mainsite.com.conf)
What would you like to do?
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 1
Deploying Certificate to VirtualHost /etc/apache2/sites-enabled/mainsite.com-le-ssl.conf
new sites, or if you’re confident your site works on HTTPS. You can undo this
change by editing your web server’s configuration.
Congratulations! You have successfully enabled https://mainsite.com and
https://www.mainsite.com
https://www.ssllabs.com/ssltest/analyze.html?d=mainsite.com
https://www.ssllabs.com/ssltest/analyze.html?d=www.mainsite.com
Congratulations! Your certificate and chain have been saved at:
/etc/letsencrypt/live/mainsite.com/fullchain.pem
/etc/letsencrypt/live/mainsite.com/privkey.pem
Your cert will expire on 2019-05-20. To obtain a new or tweaked
with the “certonly” option. To non-interactively renew all of
your certificates, run “certbot renew” -
Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
Please explain:
I see:
Please also show:
And ensure you have restarted/reloaded apache.
I go on www.mysite.com or mysite.com, it still comes up as not secure.
but when I go to https://mysite.com, it says it is secure.
OK then the problem is with the redirection only.
The cert is working fine and the site is secured.
Let’s have a look at…
grep -Eri 'servern|servera|listen|virtualh|rewrite' /etc/apache2/sites-enabled/
Nothing comes up on the terminal.
ensure you run it as root:
sudo grep …
Show:
ls -l /etc | grep apache
find / -name apache2.conf
root@Ubuntu-1804-bionic-64-minimal /etc/apache2/sites-available # find / -name apache2.conf
/etc/apache2/apache2.conf
/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot_apache/tests/testdata/debian_apache_2_4/augeas_vhosts/apache2/apache2.conf
/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot_apache/tests/testdata/debian_apache_2_4/default_vhost/apache2/apache2.conf
/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot_apache/tests/testdata/debian_apache_2_4/multiple_vhosts/apache2/apache2.conf
/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot_apache/tests/testdata/debian_apache_2_4/multi_vhosts/apache2/apache2.conf
/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot_apache/tests/testdata/complex_parsing/apache2.conf
grep -i include /etc/apache2/apache2.conf
root@Ubuntu-1804-bionic-64-minimal /etc/apache2/sites-available # grep -i include /etc/apache2/apache2.conf
# * ports.conf is always included from the main configuration file. It is
# Include module configuration:
IncludeOptional mods-enabled/*.load
IncludeOptional mods-enabled/*.conf
# Include list of ports to listen on
Include ports.conf
# Include of directories ignores editors’ and dpkg’s backup files,
# Include generic snippets of statements
IncludeOptional conf-enabled/*.conf
# Include the virtual host configurations:
IncludeOptional sites-enabled/*.conf
ls -l /etc/apache2/sites-enabled/*.conf
root@Ubuntu-1804-bionic-64-minimal /etc/apache2/sites-available # ls -l /etc/apache2/sites-enabled/*.conf
lrwxrwxrwx 1 root root 37 Feb 4 08:14 /etc/apache2/sites-enabled/othersite.com.conf -> …/sites-available/othersite.com.conf
lrwxrwxrwx 1 root root 41 Feb 4 08:07 /etc/apache2/sites-enabled/mainsite.com.conf -> …/sites-available/mainsite.com.conf
lrwxrwxrwx 1 root root 58 Feb 19 02:44 /etc/apache2/sites-enabled/mainsite.com-le-ssl.conf -> /etc/apache2/sites-available/mainsite.com-le-ssl.conf
lrwxrwxrwx 1 root root 29 Feb 3 05:51 /etc/apache2/sites-enabled/phpbb.conf -> …/sites-available/phpbb.conf
lrwxrwxrwx 1 root root 46 Feb 19 02:44 /etc/apache2/sites-enabled/phpbb-le-ssl.conf -> /etc/apache2/sites-available/phpbb-le-ssl.conf
grep -Ei 'servern|servera|listen|virtualh|rewrite' /etc/apache2/sites-available/othersite.com.conf
grep -Ei 'servern|servera|listen|virtualh|rewrite' /etc/apache2/sites-available/mainsite.com.conf
grep -Ei 'servern|servera|listen|virtualh|rewrite' /etc/apache2/sites-available/phpbb.conf
mainsite.com.conf
<VirtualHost :80>
ServerName mainsite.com
ServerAlias www.mainsite.com
RewriteEngine On
RewriteRule ^.well-known/acme-challenge/ - [L]
RewriteCond %{HTTPS} !=on
RewriteRule ^/?(.) https://%{SERVER_NAME}/$1 [R,L]
othersite.com.conf
<VirtualHost *:80>
ServerName othersite.com
ServerAlias www.othersite.com
phpbb.conf
<VirtualHost *:80>
ServerAdmin admin@ubuntu
ServerAlias ubuntu
RewriteEngine on
RewriteCond %{SERVER_NAME} =mainsite.com [OR]
RewriteCond %{SERVER_NAME} =ubuntu
<VirtualHost *:80>
ServerAlias ubuntudbz
RewriteEngine on
RewriteCond %{SERVER_NAME} =othersite.com [OR]
RewriteCond %{SERVER_NAME} =ubuntudbz
Two conflicts found:
mainsite.com.conf
ServerName mainsite.com <<<<<<<<<<<<<<<<<<<<<<<< #1
othersite.com.conf
ServerName othersite.com <<<<<<<<<<<<<<<<<<<<<<<< #2
phpbb.conf
othersite.com shouldn’t have any involvement though.
It’s a completely different site that I haven’t put a cert for.
conflicts are conflicts - you will have to address them all at some point.
Regardless the mainsite.com is at issue here and now.
I have deleted the phpbb.conf and still no difference.
(Yes, Apache2 has been restarted.)
