My domain is: opinionators.com
I ran this command: sudo certbot renew --dry-run
Attempting to renew cert (opinionators.com) from /etc/letsencrypt/renewal/opinionators.com
conf produced an unexpected error: Failed authorization procedure.
opinionators.com (http-01): urn:ietf:params:acme:error:unauthorized ::
The client lacks sufficient authorization::
Invalid response from http://opinionators.com/.well-known/acme-challenge/lLQkufcdHfJmDY71WBvyxNxrSfub45M7U2yLrOKgE8U
[34.98.99.30]: "<!doctype html><html lang=\"en\"><head><meta http-equiv=\"content-type\" content=\"text/html;charset=utf-8\">
<meta name=\"viewport\"con", www.opinionators.com (http-01): urn:ietf:params:acme:error:unauthorized ::
The client lacks sufficient authorization ::
Invalid response from http://www.opinionators.com/.well-known/acme-challenge/Bd_FJE5zK6qOPBad5agvdF7E5os1mVBQG67VcsSmv-8
<meta http-equiv=\"content-type\" content=\"text/html;charset=utf-8\"><meta name=\"viewport\" con". Skipping.
/etc/letsencrypt/live/opinionators.com/fullchain.pem (failure)
My web server is (include version): Apache/2.4.29
The operating system my web server runs on is (include version): Ubuntu 18.04.4 LTS
My hosting provider, if applicable, is: DigitalOcean (Wordpress droplet)
The version of my client is: certbot 0.31.0
I have a Wordpress droplet in DigitalOcean for a year now, and I always had problems with redirection, however the HTTPS version always worked.
Now suddenly, neither of the versions work, and I can only access https://134.122.81.36/ without seeing files that try to access opinionators.com.
