* Trying 172.65.32.248:443...
* Connected to acme-v02.api.letsencrypt.org (172.65.32.248) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* CAfile: /etc/ssl/certs/ca-certificates.crt
* CApath: /etc/ssl/certs
* TLSv1.0 (OUT), TLS header, Certificate Status (22):
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* TLSv1.2 (IN), TLS header, Certificate Status (22):
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS header, Finished (20):
* TLSv1.2 (IN), TLS header, Supplemental data (23):
* TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
* TLSv1.3 (IN), TLS handshake, Certificate (11):
* TLSv1.3 (IN), TLS handshake, CERT verify (15):
* TLSv1.3 (IN), TLS handshake, Finished (20):
* TLSv1.2 (OUT), TLS header, Finished (20):
* TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.2 (OUT), TLS header, Supplemental data (23):
* TLSv1.3 (OUT), TLS handshake, Finished (20):
* SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384
* ALPN, server accepted to use h2
* Server certificate:
* subject: CN=acme-v02.api.letsencrypt.org
* start date: Sep 2 19:13:12 2022 GMT
* expire date: Dec 1 19:13:11 2022 GMT
* subjectAltName: host "acme-v02.api.letsencrypt.org" matched cert's "acme-v02.api.letsencrypt.org"
* issuer: C=US; O=Let's Encrypt; CN=R3
* SSL certificate verify ok.
* Using HTTP2, server supports multiplexing
* Connection state changed (HTTP/2 confirmed)
* Copying HTTP/2 data in stream buffer to connection buffer after upgrade: len=0
* Using Stream ID: 1 (easy handle 0x564246814c60)
> GET /directory HTTP/2
> Host: acme-v02.api.letsencrypt.org
> user-agent: curl/7.81.0
> accept: */*
* TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):
* old SSL session ID is stale, removing
* Connection state changed (MAX_CONCURRENT_STREAMS == 128)!
< HTTP/2 200
< server: nginx
< date: Fri, 14 Oct 2022 07:23:14 GMT
< content-type: application/json
< content-length: 659
< cache-control: public, max-age=0, no-cache
< x-frame-options: DENY
< strict-transport-security: max-age=604800
"d4o6U8Rk21k": "https://community.letsencrypt.org/t/adding-random-entries-to-the-directory/33417",
"meta": {
"caaIdentities": [
"letsencrypt.org"
"termsOfService": "https://letsencrypt.org/documents/LE-SA-v1.3-September-21-2022.pdf",
* Connection #0 to host acme-v02.api.letsencrypt.org left intact
