Http to https redirect does not work
genemattos.com
Apache2
Ubuntu 19.10
Linode
Yes
No
certbot 1.3.0
https://www.genemattos.com works
http://www.genemattos.com does not work
.conf file is below
<VirtualHost *:80>
ServerName www.genemattos.com
DocumentRoot /var/www/html
RewriteEngine on
#RewriteCond %{SERVER_NAME} =genemattos.com [OR]
RewriteCond %{SERVER_NAME} =www.genemattos.com
Try
<Directory />
    Require all denied
</Directory>
Alias /.well-known/acme-challenge /var/www/acme
<Directory /var/www/acme>
    Options None
    AllowOverride None
    Require all granted
</Directory>
<Directory /var/www/html>
    Redirect permanent / https://www.genemattos.com
</Directory>
Run this command and tell me if tells you something like “Listen 80” somewhere:
grep -ir "Listen" /etc/apache2
Also check your firewall on port 80.
