My domain is: trj.it
sudo wget https://dl.eff.org/certbot-auto
sudo mv certbot-auto /jet/etc/letsencrypt/certbot-auto
sudo chown root /jet/etc/letsencrypt/certbot-auto
sudo chmod 0755 /jet/etc/letsencrypt/certbot-auto
sudo chmod a+x /jet/etc/letsencrypt/certbot-auto
sudo /jet/etc/letsencrypt/certbot-auto --nginx --nginx-ctl /jet/bin/nginx --nginx-server-root /jet/etc/nginx --config-dir /jet/etc/letsencrypt
during the installation he asked me to choose between two options and I chose always redirect
I installed the certificates
ERROR HTTP while I try to upload a file.
I am not able to upload file through the admin panel of my CMS
http://jetware.io/appliances/jetware/lemp7_optimized_g2-170723/profile
Linux lemp7-optimized-g2-1-vm 4.9.0-8-amd64 #1 SMP Debian 4.9.110-3+deb9u4 (2018-08-21) x86_64
My hosting provider, if applicable, is: GOOGLE CLOUD COMPUTE ENGINE
I can login to a root shell on my machine (yes or no, or I don’t know): YES SSH
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):NO
or certbot-auto --version
if you’re using Certbot):certbot-auto
During the installation it asked me to choose between two options and I chose always redirect. I think this was the wrong option because it is as if the site were armored, which is fine but I need to use the control panel for uploading.
The question is: is there any option I can change ?
Or you can kindly write the commands to be able to safely delete the certificates and then proceed with a new installation. Should certificates be revoked first ?
