I just bought a new server, and want to follow this for www.pretty-formula.com. After putting pretty-formula.com
in related files, I got this error:
root@iZj6ce932fiflob4gudnajZ:~/nginx-certbot# ./init-letsencrypt.sh
Existing data found for pretty-formula.com. Continue and replace existing certificate? (y/N) y
### Creating dummy certificate for pretty-formula.com ...
Generating a RSA private key
writing new private key to '/etc/letsencrypt/live/pretty-formula.com/privkey.pem'
failed to resize tty, using default size
### Starting nginx ...
Recreating nginx-certbot_nginx_1 ... done
### Deleting dummy certificate for pretty-formula.com ...
### Requesting Let's Encrypt certificate for pretty-formula.com ...
http-01 challenge for pretty-formula.com
http-01 challenge for www.pretty-formula.com
Using the webroot path /var/www/certbot for all unmatched domains.
Challenge failed for domain pretty-formula.com
Challenge failed for domain www.pretty-formula.com
Domain: pretty-formula.com
Type: connection
Detail: Fetching
http://pretty-formula.com/.well-known/acme-challenge/-yXehDZroR0bFBusF3tEM9Ja9tD1XEXDmAiDnWgP6u8:
Connection refused
Domain: www.pretty-formula.com
Type: connection
Detail: Fetching
http://www.pretty-formula.com/.well-known/acme-challenge/KbU_eUlIBexvG1zqN-UKB7lhdiIc7MEOYar1w-vlPNs:
Connection refused
### Reloading nginx ...
cannot exec in a stopped state: unknown
Here is the record I added to pretty-formula.com
It’s a very new domain, I don’t understand what’s blocking.
Thank you
