This is not due to the certificate per se, but is due to a misconfiguration in your webserver configuration. Separating your certificates into two certs doesn't automatically fix your Apache configuration
I see you're running Apache on a Windows system, so it couldn't have been caused by certbot, as certbot currently doesn't have the apache
plugin working on Windows systems.
This is a Community and we only help through the Community itself, so other people with perhaps the same issue might benefit from it. We don't do support through e-mail.
I've also moved your thread to the #Help section as this clearly isn't a Feature request. Also, in the #Help section you would have been presented with a questionnaire. Please also fill in the questionnaire to the best of your knowledge and if you don't know the answer, please don't leave it blank, but answer that you don't know. Here's the questionnaire:
or certbot-auto --version
if you're using Certbot):
