I am struggling for some time to make following ‘architecture’ to work: There is a publicly available server on which I run NGINX. It actually only redirect HTTP(S) requests to other NGINX instances running on VMs (so I don’t have to use different ports, set port forwarding, etc).HTTP works, but I wanted to add certificates and improve security.
Seems that I am missing something and not sure what. Main puzzle for me is: shall I create LE SSL certificates on server, on VM where ‘target’ NGINX is running or on both? Currently I use both: on main server there are ‘root’ domain certificates and on VM are '‘subudomain’ certs.
Any help/advice is more than welcome.
Here is the ‘main’ NGINX config file (/etc/nginx/sites-enabled/default) located on server:
server { listen 80 default_server; listen [::]:80 default_server; server_name main.org www.main.org; return 301 https://$server_name$request_uri; } server { # SSL configuration listen 443 ssl http2 default_server; listen [::]:443 ssl http2 default_server; ssl on; ssl_certificate /etc/letsencrypt/live/www.main.org/fullchain.pem; ssl_certificate_key /etc/letsencrypt/live/www.main.org/privkey.pem; ssl_protocols TLSv1 TLSv1.1 TLSv1.2; ssl_prefer_server_ciphers on; ssl_ciphers "EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH"; ssl_ecdh_curve secp384r1; ssl_session_cache shared:SSL:10m; ssl_session_tickets off; ssl_stapling on; ssl_stapling_verify on; resolver 8.8.8.8 8.8.4.4 valid=300s; resolver_timeout 5s; add_header Strict-Transport-Security "max-age=63072000; includeSubdomains"; add_header X-Frame-Options DENY; add_header X-Content-Type-Options nosniff; ssl_dhparam /etc/ssl/certs/dhparam.pem; # Session timeout value must be properly set in /etc/wok/wok.conf as well ssl_session_timeout 10m; root /var/www/html; # Add index.php to the list if you are using PHP index index.html index.htm index.nginx-debian.html; server_name _; location / { # First attempt to serve request as file, then # as directory, then fall back to displaying a 404. try_files $uri $uri/ =404; } location ~ /.well-known { allow all; } }
Following is the content of subsite NGINX config (/etc/nginx/sites-enabled/subsite) - also on main server.
192.168.0.24:80 is the HTTP endpoint of subdomain NGINX. This address is not visible from outer world.
Notice that I here I am also using www.main.org certificate - which is probably wrong, but could not create LE certificate for this site; got 404 Not Found and command was: sudo letsencrypt certonly --renew-by-defaul --agree-tos --staging --webroot -m nikoladsp@gmail.com -w /var/www/html -d www.subsite.org
server { listen 80; server_name subsite.org www.subsite.org; access_log /var/log/nginx/subsite.access.log; error_log /var/log/nginx/subsite.log; include /etc/nginx/snippets/letsencrypt-acme-challenge.conf; location / { return 301 https://$server_name$request_uri; } } server { listen 443; server_name subsite.org www.subsite.org; ssl on; ssl_certificate /etc/letsencrypt/live/www.main.org/fullchain.pem; ssl_certificate_key /etc/letsencrypt/live/www.main.org/privkey.pem; ssl_protocols TLSv1 TLSv1.1 TLSv1.2; ssl_prefer_server_ciphers on; ssl_ciphers "EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH"; ssl_ecdh_curve secp384r1; ssl_session_cache shared:SSL:10m; ssl_session_tickets off; ssl_stapling on; ssl_stapling_verify on; resolver 8.8.8.8 8.8.4.4 valid=300s; resolver_timeout 5s; add_header Strict-Transport-Security "max-age=63072000; includeSubdomains"; add_header X-Frame-Options DENY; add_header X-Content-Type-Options nosniff; ssl_dhparam /etc/ssl/certs/dhparam.pem; # Session timeout value must be properly set in /etc/wok/wok.conf as well ssl_session_timeout 10m; access_log /var/log/nginx/subsite.access.log; error_log /var/log/nginx/subsite.log; location / { proxy_pass http://192.168.0.24:80; proxy_next_upstream error timeout invalid_header http_500 http_502 http_503 http_504; proxy_redirect off; proxy_buffering off; proxy_set_header Host $host; proxy_set_header X-Real-IP $remote_addr; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; proxy_set_header X-Forwarded-Proto $scheme; } }
Content of /etc/nginx/snippets/letsencrypt-acme-challenge.conf is as follows:
# Rule for legitimate ACME Challenge requests (like /.well-known/acme-challenge/xxxxxxxxx) # We use ^~ here, so that we don't check other regexes (for speed-up). We actually MUST cancel # other regex checks, because in our other config files have regex rule that denies access to files with dotted names. location ^~ /.well-known/acme-challenge/ { # Set correct content type. According to this: # https://community.letsencrypt.org/t/using-the-webroot-domain-verification-method/1445/29 # Current specification requires "text/plain" or no content header at all. # It seems that "text/plain" is a safe option. default_type "text/plain"; # This directory must be the same as in /etc/letsencrypt/cli.ini # as "webroot-path" parameter. Also don't forget to set "authenticator" parameter # there to "webroot". # Do NOT use alias, use root! Target directory is located here: # /var/www/common/letsencrypt/.well-known/acme-challenge/ root /usr/share/nginx/html; } # Hide /acme-challenge subdirectory and return 404 on all requests. # It is somewhat more secure than letting Nginx return 403. # Ending slash is important! location = /.well-known/acme-challenge/ { return 404; }
Finally, on subdomain NGINX running in VM; config file (/etc/nginx/sites-enabled/default) looks like:
server { listen 80 default_server; listen [::]:80 default_server; server_name subsite.org www.subsite.org; location ~ /.well-known { allow all; } location / { return 301 https://$server_name$request_uri; } } server { # SSL configuration listen 443 ssl http2 default_server; listen [::]:443 ssl http2 default_server; ssl on; ssl_certificate /etc/letsencrypt/live/subsite.org/fullchain.pem; ssl_certificate_key /etc/letsencrypt/live/subsite.org/privkey.pem; ssl_protocols TLSv1 TLSv1.1 TLSv1.2; ssl_prefer_server_ciphers on; ssl_ciphers "EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH"; ssl_ecdh_curve secp384r1; ssl_session_cache shared:SSL:10m; ssl_session_tickets off; ssl_stapling on; ssl_stapling_verify on; resolver 8.8.8.8 8.8.4.4 valid=300s; resolver_timeout 5s; add_header Strict-Transport-Security "max-age=63072000; includeSubdomains"; add_header X-Frame-Options DENY; add_header X-Content-Type-Options nosniff; ssl_dhparam /etc/ssl/certs/dhparam.pem; # Session timeout value must be properly set in /etc/wok/wok.conf as well ssl_session_timeout 10m; root /var/www/html; # Add index.php to the list if you are using PHP index index.html index.htm index.nginx-debian.html; server_name _; location / { # First attempt to serve request as file, then # as directory, then fall back to displaying a 404. try_files $uri $uri/ =404; } }
