How to renew certificate
My domain is: www.quickrize.com
I ran this command: www.quickrize.com
It produced this output: This site can’t be reached
Check if there is a typo in quickrize.com.
  • If spelling is correct, [try running Windows Network Diagnostics](javascript:diagnoseErrors()).
DNS_PROBE_FINISHED_NXDOMAIN
The domain you specified appears to have been expired:
$ whois quickrize.com
   Registry Expiry Date: 2024-05-31T07:31:07Z
   Name Server: DNS10.PARKPAGE.FOUNDATIONAPI.COM
   Name Server: DNS11.PARKPAGE.FOUNDATIONAPI.COM
Tripple check if there's no a typo?
Yes it is expired and I want to renew it. How to do it?
In the mail I received from Letsencrypt, the certificate will expire on 14. Please help me renew it
Let's Encrypt is the certificate authority that issues SSL/TLS certificates, it's not a domain registrar. You need to go where you bought your domain and manage it from there. According to the whois record, your registrar appears to be “PublicDomainRegistry”.
Ok. I want to renew my SSL certificate. please help
You cannot get a certificate for a domain that does not exist or is expired, as you won't be able to demonstrate your control over it to Let's Encrypt (or any other Certificate Authority for that matter).
Getting a certificate is the least of your worries at the moment, you need to regain control over the domain first, as quickly as you can. Before someone else snatches it.
Here is the RDAP info for your domain. I'm guessing maybe you used to pay for your domain through domain.com maybe? Anyway, you perhaps didn't pay the bill because as @Nekit says the domain has expired at the end of May (not the certificate, the actual website domain name quickrize.com) and is pending deletion by your registrar. You need to speak to them (or whoever you normally pay for the domain) quickly or you will lose the domain forever.
 rdap quickrize.com
# Registrar Error: RDAP server returned 404, object does not exist.
RDAP from Registry:
Domain:
  Domain Name: QUICKRIZE.COM
  Handle: 2269861236_DOMAIN_COM-VRSN
  Status: pending delete
  Conformance: rdap_level_0
  Conformance: icann_rdap_technical_implementation_guide_0
  Conformance: icann_rdap_response_profile_0
  Notice:
    Title: Terms of Use
    Description: Service subject to Terms of Use.
    Link: https://www.verisign.com/domain-names/registration-data-access-protocol/terms-service/index.xhtml
  Notice:
    Title: Status Codes
    Description: For more information on domain status codes, please visit https://icann.org/epp
    Link: https://icann.org/epp
  Notice:
    Title: RDDS Inaccuracy Complaint Form
    Description: URL of the ICANN RDDS Inaccuracy Complaint Form: https://icann.org/wicf
    Link: https://icann.org/wicf
  Link: https://rdap.verisign.com/com/v1/domain/QUICKRIZE.COM
  Link: https://rdapserver.net/domain/QUICKRIZE.COM
  Event:
    Action: registration
    Date: 2018-05-31T07:31:07Z
  Event:
    Action: expiration
  Event:
    Action: last changed
    Date: 2024-08-12T11:08:05Z
  Event:
    Action: last update of RDAP database
    Date: 2024-08-13T03:30:06Z
  Secure DNS:
    Delegation Signed: false
  Entity:
    Handle: 303
    Public ID:
      Type: IANA Registrar ID
      Identifier: 303
    Role: registrar
    vCard Version: 4.0
    vCard Name: PDR Ltd. d/b/a PublicDomainRegistry.com
    Entity:
      Role: abuse
      vCard Version: 4.0
      vCard Tel: +1.2013775952
  Nameserver:
    Nameserver: DNS10.PARKPAGE.FOUNDATIONAPI.COM
  Nameserver:
    Nameserver: DNS11.PARKPAGE.FOUNDATIONAPI.COM
