I successfully installed certbot for my two domains and virtual hosting with apache Web server.
Is it possible to remove two wrong entries from the interactive menu certbot certonly --apache? The certificates are not provided since the URL is wrong.
Thank you
Hi @erotavlas
Certbot doesn't create an interactive menu. So it's a function of that menu -> check that documentation.
thank you for the fast reply. I did not say that cerbot creates an interactive menu. If you execute the above command certbot certonly --apache
you will see an interactive menu with two entries that I would like to remove. Is it possible? I did not find it on documentation.
That's something of your machine. Nothing I can see.
Do you have a screenshot?
This is the message:
sudo certbot certonly --apache
Plugins selected: Authenticator apache, Installer apacheWhich names would you like to activate HTTPS for?
1: example1.org
2: www.example1.org
3: example2.org
4: www.mexample2.org
blank to select all options shown (Enter ‘c’ to cancel):
I would like to remove 2 and 4 even if they do not have any certificate.
If you use that command, Certbot asks.
So start with
sudo certbot certonly --apache -d example1.org -d example2.org
Certbot just parses your Apache configuration for ServerName
and ServerAlias
directives to make the list of potential names.
If you want to totally get rid of a site, you can delete it from your Apache configuration.
I don’t think Certbot has a feature to exclude names it finds in Apache from the list. But you don’t have to choose to issue certificates for them.
