How to modify an existing certificate
#1
My domain is: cineycomics.com
My operating system is (include version): CentOS 7
My hosting provider, if applicable, is: Nominalia Internet
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): CWP7
I created a certificate for my domain cineycomics.com using the LetsEncrypt section inside Apache on my server control pannel, but I didn’t check the www alias.
Now I want to include the www.cineycomics.com URL inside the certificate. Or create it again. Is any of this possible?
Thanks.
#2
Just create a new one. Modification isn’t possible, as this would render the signature invalid.
#3
But when I try to create it again, it says it already exists, so I can’t do it again…
How can I delete the existing one or remove it from my server?
#4
That probably has something to do with the control panel you’re using, it surely isn’t a Let’s Encrypt thing.
#5
