How to Initialize Certbot to create the initial file structure when using --manual mode
My domain is: mountaintrips.com
I ran this command: sudo apt install certbot
It produced this output: N/A
My web server is (include version): manual mode
The operating system my web server runs on is (include version): ubuntu 18.04
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 1.0.0.0
When you install Certbot, it seems only the basic file structure is created. /etc/letsencrypt and /var/log/letsencrypt, etc…
When you run it for the first time, the additional required file structure for LE is created /letsencrypt/renewal, live, renewal-hooks, etc…
But if you are using --manual mode, and are going to specify custom authentication, deploy, and cleanup scripts, is there a way to initialize Certbot without having to run it once with --standalone --dry-run to let it fail and create the structure? Or do I have to create this structure manually and assign the correct permissions?
