How to group count entries for multiple sub-domains in crt.sh
My parent domain is: relexsolutions.com
I took the following steps: I navigated to https://crt.sh/ and made around 20 manual queries (since we have a lot of sub-domains under that parent domain)
I would like to ask if there is an easier way to do this in the future?
Thank you, Kind Regards Taneli
Have you asked crt.sh already? As that is a website that is not affiliated with Let's Encrypt.
Oh, I didn't even realize that. Thank you @Osiris for helping me out :+1:
B.R. Taneli
They allow you to make queries using SQL directly on their backend. (postgres)
... or you can just make a search for the parent domain, and all the subdomains will appear.
One could possibly use wget to download the current report and save the file locally:
wget -O certlist.html https://crt.sh/?q=relexsolutions.com
:smiling_imp:
Outside the scope of this forum!
Thank you both for your help. I really appreciate it :+1:
B.R. Taneli
