How to generate renewal certificates will expire
#1
Hello!
I got mail that these certificates will expire
static.kassakaappi.net
template.kassakaappi.net
www.kassakaappi.net
So I run: /root/certbot-auto renew
this does not help with these problem.
I got: /etc/letsencrypt/renewal
only this with kassakaappi
www.kassakaappi.net.conf
Other websites I got these files
x.fi.conf
static.x.fi.conf
template.x.fi.conf
And other websites working ok.
So what I do that I can have these files too with kassakaappi ?
Here: /etc/apache2/sites-available
Other sites
x.conf
x-le-ssl.conf
static.x.conf
static.x-le-ssl.conf
template.conf
template.x-le-ssl.conf
And kassakaappi:
kassakaappi.conf
kassakaappi-le-ssl.conf
template.kassakaappi.conf
template.kassakaappi-le-ssl.conf
static.kassakaappi.conf
static.kassakaappi-le-ssl.conf
But inside these files other *le-ssl.conf files end like this
example: eco-toimistotatvikkeet-le-ssl.conf
SSLCertificateFile /etc/letsencrypt/live/hiekkalaatikko.eco-toimistotarvikkeet.fi/cert.pem
SSLCertificateKeyFile /etc/letsencrypt/live/hiekkalaatikko.eco-toimistotarvikkeet.fi/privkey.pem
SSLCertificateChainFile /etc/letsencrypt/live/hiekkalaatikko.eco-toimistotarvikkeet.fi/chain.pem
example: template.eco-toimistotatvikkeet-le-ssl.conf
SSLCertificateFile /etc/letsencrypt/live/template.eco-toimistotarvikkeet.fi/cert.pem
SSLCertificateKeyFile /etc/letsencrypt/live/template.eco-toimistotarvikkeet.fi/privkey.pem
SSLCertificateChainFile /etc/letsencrypt/live/template.eco-toimistotarvikkeet.fi/chain.pem
But all kassakaappi *.le-ssl.conf files
end like this:
SSLCertificateFile /etc/letsencrypt/live/www.kassakaappi.net/cert.pem
SSLCertificateKeyFile /etc/letsencrypt/live/www.kassakaappi.net/privkey.pem
SSLCertificateChainFile /etc/letsencrypt/live/www.kassakaappi.net/chain.pem
So how I can get that template.kassakaappi static.kassakaappi
get /etc/letsencrypt/live/ those certificates?
Or is this one /etc/letsencrypt/live/www.kassakaappi.net/chain.pem
enough for these sites:
www.kassakaappi.net
What should I do ? To get certificates for these sites?Or do I do it afterall ?
Is there everything allright?
Yours Timo
#2
Your sites certificates were renewed on the 8th Oct, there is nothing you need to do, everything looks OK.
#3
Thank you for your answer! I just wonder why I got this mail:
"Your certificate (or certificates) for the names listed below will expire in 10 days (on 25 Oct 16 07:14 +0000). Please make sure to renew your certificate before then, or visitors to your website will encounter errors.
www.kassakaappi.net"
Are listed sites too working after 25 Oct 16 ?
Other sites which I do not mention works after that
but what about those listed sites?
#4
You got the email because in July you obtained a cert for
DNS:hiekkalaatikko.kassakaappi.net
DNS:kassakaappi.net
DNS:static.kassakaappi.net
DNS:template.kassakaappi.net
DNS:www.kassakaappi.net
This certificate from July is due for renewal, however you have obtained a different certificate in August for;
hiekkalaatikko.proficient.fi
kassakaappi.net
proficient.fi
static.eco-toimistotarvikkeet.fi
static.proficient.fi
template.proficient.fi
vanha.kassakaappi.net
www.eco-toimistotarvikkeet.fi
www.kassakaappi.net
www.proficient.fi
Since this second certificate was not a renewal, but a new certificate, the system is telling you that the original one is due for renewal, in reality though you have all the domain names covered on a different certificate, which you have renewed (8th October)
#5
Thank you very much! for your answer.
It’s clear now.
#6
