My domain is: nappetito.com
I ran this command: sudo certbot -d *.nappetito.com
Then it asks me to choose between these:
2: Renew & replace the certificate (may be subject to CA rate limits)
Here I permanently prefer 1 and then after pressing enter, it is asking for this to select the subdomains in the virtual host that I want to generate certificates:
In this case I permanently prefer press to "Enter" button to generate certificate for all.
Is there possibility to use one command instead of above steps to generate certificates? I'm trying to generate certificates programmatically.
