How to extend duration of issue
does anybody know how to extend duration of issue ?
our website is : https://www.hadaf.host
just follow these steps :
https://certbot.eff.org/lets-encrypt/ubuntubionic-apache
and tell me to know if any problem
Hi @masnas
I’ve moved your question to an own topic, makes things easier.
I don’t really understand your question.
Checking your domain there are some Letsencrypt certificates ( https://check-your-website.server-daten.de/?q=hadaf.host#ct-logs ).
Let’s Encrypt Authority X3 2019-07-01 2019-09-29 domain.hadaf.host - 1 entries
Let’s Encrypt Authority X3 2019-06-14 2019-09-12 stage.hadaf.host - 1 entries
Let’s Encrypt Authority X3 2019-05-26 2019-08-24 status.hadaf.host - 1 entries
Let’s Encrypt Authority X3 2019-05-23 2019-08-21 blog.hadaf.host, design.hadaf.host, learn.hadaf.host, panel.hadaf.host, static.hadaf.host - 5 entries
Let’s Encrypt Authority X3 2019-05-20 2019-08-18 mautic.hadaf.host - 1 entries
Let’s Encrypt Authority X3 2019-05-17 2019-08-15 cpanel.hadaf.host, hadaf.host, hadafnet.co, mail.hadaf.host, mail.hadafnet.co, webdisk.hadaf.host, webmail.hadaf.host, whm.hadaf.host, www.hadaf.host, www.hadafnet.co - 10 entries
Let’s Encrypt Authority X3 2019-05-14 2019-08-12 *.hadaf.host, hadaf.host - 2 entries
Let’s Encrypt Authority X3 2019-05-01 2019-07-30 domain.hadaf.host - 1 entries
Different subdomains, one cPanel with 10 domain names.
Your main configuration is ok, but /.well-known/acme-challenge is redirected to your /.
http://hadaf.host/
95.216.99.104 301 https://hadaf.host/ 1.513 A
http://www.hadaf.host/
95.216.99.104 301 https://www.hadaf.host/ 1.433 A
https://hadaf.host/
95.216.99.104 301 https://www.hadaf.host/ 2.530 B
95.216.99.104 200 2.753 I
http://hadaf.host/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
95.216.99.104 301 https://www.hadaf.host 1.470 E
Visible Content:
http://www.hadaf.host/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
95.216.99.104 301 https://www.hadaf.host 1.770 A
Visible Content:
https://www.hadaf.host 200 3.064
May be a problem creating new Letsencrypt certificates.
So specify your question:
Hi @masnas,
Do you mean how to obtain a certificate with a validity longer than 90 days?
Let’s Encrypt is meant to be used together with automation and there is no way to obtain a certificate with a different validity period. All Let’s Encrypt certificates are always valid for exactly 90 days.
