How to determine for which certificate I am using TLS-SNI-01 validation
#1
My domain is:multiple domains, among atlassian.ngti.nl, robotics.swisscom.ch
I received an email, that one of my Let’s Encrypt clients has used in the past 60 days the TLS-SNI-01 validation.
As I am using multiple certificates, and thought I checked all and couldn’t find the culprit, is there a way to determine which one is using the TLS-SNI-01 validation, which reaches end-of-live on February 13th?
#2
At the moment, the only way to identify this would be to update your Certbot clients to at least 0.28, and then:
certbot renew --dry-run
If you are using TLS-SNI in that instance, it will complain/warn you about it.
#3
